Intel® ARC™ Graphics
3294 Discussions
B580 Graphics card fans not working
Darrell2
installed new ASRock challenger b650 graphics card and fans are not running. Are they temperature controlled or is this a problem??
mhabooth
I just bought it yesterday, it just less than 24 hours and I also found the same issue. Fans are not spinning. If i restart fan just spin for few seconds then it goes off automatically. However i also did GPU stress test and it is actually working fine.
Go to the below link for stress test. Start the testing then set 1000 as number of spheres then click apply for test then ok. Instatall HWmonitor or HWinfo and check GPU fan RPM. Make sure your GPU is working at 100% load. Hope this is work. If at 100% load fan is not spinning then there might be issues.
https://www.matthew-x83.com/online/gpu-test.php
Model: Gunnier Intel Arc B580 Photon
