Intel® ARC™ Graphics
3360 Discussions
CS2 crashes
Bandit8623
New Contributor III
cs2 crashes.  game just closes no error.  5333 driver.  same happens for valorant.  driver 5194 no crashes
1440p 
Bandit8623
New Contributor III
@RonaldM_Intel
Looks like i had unstable ram in my pc.  ran prime95 on ram test and got errors in 20min.  i since have rectified the ram.  my guess this was the crash reasons.  ill know more over the weekend as i have some val and cs matches this sunday.
thanks
Bandit8623
New Contributor III
adding another
Bandit8623
New Contributor III
another
RonaldM_Intel
Hi @Bandit8623
Sorry for answering until now... it has been a busy week.
Have you experienced any other crash on CS2 since then? The reason I'm asking is because I have been testing and benchmarking CS2 for a while now and haven't experienced any crash yet (not even on 101.5333). Is it crashing more often on any map or game mode?
By the way, I analyzed the dump files you submitted (thanks by the way!) and from the 3 dumps:
1. crash_cs2.exe_20240308221419_1.dmp -> failure occurred with 'engine2.dll' component.
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_engine2.dll!Unknown
2. crash_cs2.exe_20240308211156_1.dmp -> failure occurred with 'rendersystemdx11.dll' component.
FAILURE_BUCKET_ID: NULL_POINTER_READ_c0000005_rendersystemdx11.dll!Unknown
3. crash_cs2.exe_20240308200045_1.dmp -> failure occurred with 'igd10umt64xe.dll' component.
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_igd10umt64xe.DLL!Unknown
Out of the 3 only 1 crash is related to a driver component (igd10umt64xe.dll) so I'll look into it but it might have been due to an incorrect app call. The other 2 crashes are related to the application itself so there may be more happening there. Have you reinstalled the game?
Ronald M.
Bandit8623
New Contributor III
@RonaldM_Intel
thanks for looking into.  I will do some game reloading and pc stability tests in the next few days.  since valorant is crashing too its possible i have a hardware stability elsewhere.   ill update when i know more
thx
Bandit8623
New Contributor III
@RonaldM_Intel
CONFIRMED no crashing since fixing ram stability.
Bandit8623
New Contributor III
@RonaldM_Intel
thanks
