Intel® ARC™ Graphics
3286 Discussions
Delta Force performance issue
GoldPlay
my arc a580 driver is 32.0.101.6319.In delta force i am getting around 15-17 fps and audio is bad too.
i also tried WQHL certified 32.0.101.6314 ,both has same problem.
i noticed that my gpu only consume 40w while playing delta force,other games do'nt have this problem.
my cpu is rayzen 7600,re-bar enabled.
DhannielM_Intel
Hello GoldPlay,
As I was comparing the CapframeX files you sent, I noticed that one file shows an average FPS of around 100, while the other two show averages of 60-50 FPS. These FPS values are quite good for a demanding game like Delta Force. However, could you confirm if all three files were captured under Warfare Mode with the same settings as before?
Additionally, as for the sound of the game since you are using a TWS Bluetooth device, I think it is best you contact the device manufacturer about or maybe the game developers.
Dhanniel M.
DhannielM_Intel
Hello GoldPlay,
I hope you're doing well. I wanted to follow up and see if you've had a chance to review my previous message. I'll be awaiting your response.
Dhanniel M.
DhannielM_Intel
Hello GoldPlay,
Since I haven't heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
Orion0001
Hello mate, did you fix fps drop. If you did, pls let me know how
I can't play delta force after last driver update. Thnks
dxbag
Bumping this thread.
Using an ARC 770 ROC sparkle card.
I get frame stutters every minute or so. I tried the different suggestion through out this forum and had no luck. on an i5 12600kf processor with 32gigs of ddr5 ram and an m.2 SSD.
