- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
Thank you for joining the Intel Communities. We understand that experiencing crashing issues may be frustrating, and we will be more than glad to help you. To better troubleshoot your problem, we would like to request some details, please, provide us with the following:
- When did the crashing issue start? It's been there since you installed the A770?
- Did you have another graphics card before you installed the Intel Arc graphics adapter?
- Which distribution service do you use to install the games? We understand that you may have used different options, but we would like to know the options you used for all three games. (Steam, Epic Games, Microsoft Store, Xbox Store)
- We would like to if your system is up to date and look at some details about your system environment. Share with us a report using the Intel SSU:
- Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; and then "Save.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Many users are having game crashing problems on intel arc a770. Please sir fix this issue as soon as possible. I would not buy a intel gpu if I were not an intel fan. But now I am disappointed. But I have faith in intel. Please fix the game crashing issues asap.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
We understand the issue may be affecting other users, and we invite any community member experiencing the problem to join in the conversation. However, the information we have requested will help us to assist you more efficiently, so please, provide us with the information we requested before to better look into this matter.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
Reviewing your system report, we noticed that you have driver 31.0.101.4885; however, there is a new driver version available, 31.0.101.4887. We recommend you update the driver, but before, we recommend you run the Display Driver Uninstaller to eliminate all previous driver residues. Check How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver for instructions.
However, there is still some information missing, so please provide us with the following:
- When did the issue start? We would like to check if the issue started after a driver or Operating System update.
- We want to confirm the game distribution service you used to install the game, to use the same option as you, in case we need to replicate the issue.
- Did you have another graphics card before the Intel Arc graphics adapter? Having driver files from a third-party graphics card can affect the functionality of the new graphics card.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
My latest driver 31.0.101.4887 crashed today with a driver crashing message While playing valorant.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
We understand that you have experienced crashing issues in Valorant with the new driver 31.0.101.4887. However, we would like to know if you have been able to run the DDU tool. In case you haven't, you should eliminate all the previous drivers and leftovers with the DDU software.
There is some vital information missing that will help us to better assist you and further investigate this matter. Could you please share with us the information we requested before?
We also would like to inform you that we recommend reporting one issue per thread to keep things organized. We understand that all the games you have mentioned suffered from a similar crashing problem. However, since they all are different software, the reason behind the crash may be different for each other. We will continue to support the Far Cry 6 crashing issue in this thread. We invite you to open another thread for the Forza Horizon 5 and Valorant. We would like to know if the issue improved when playing Far Cry 6.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Why the latest driver of intel gpu crashing while gaming ? I think i did mistake to buy intel gpu.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
We understand your frustration after seeing that multiple game titles are crashing. We were asking for more information about your system and issue to further look into this matter internally and discard if the problem is related to the graphics driver, and the troubleshooting recommendation we provided can help you solve the issue. However, we will proceed to look into this matter internally, and we will post back as soon as we have more details.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
Thank you for the information provided. After looking into this matter internally, we would like to inform you that, as we mentioned before, we will assist you with the Far Cry 6 crashing issue. However, we would like to request more information about your issue to further look into this matter, so please provide us with the following details:
- Which distribution service do you use to install the Far Cry 6 game? We would like to know the options you used for all three games. (Steam, Epic Games, Microsoft Store, Xbox Store)
- To discard that the issue is due to a driver regression problem, we want to know if the issue started after a Driver update. If so, let us know the latest working driver version.
- Did you have another graphics card before you installed the Intel Arc graphics adapter? Sometimes, files from previous graphics cards can cause the new adapter to not work as expected, so we want to discard this possibility.
- Were you able to discard the run of the DDU tool? Remember that this suggestion is based on the idea that there may be corrupted files from previous driver installations that can affect the new driver and impact system stability
- Finally, we would like to know if there is anything special that triggers the crashing issue. Maybe the issue is related to a game location or even action. Therefore, we would like to ask if there is a particular step to replicate the problem. You previously mentioned that the issue occurred after playing for some time, but we would like to know if there is anything else you have noticed lately.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
i am facing crash in almost all games i played. i cant play games like this.even m discord crash..i have facing crash on cs2, valorant, fr6, fh5 .
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
do you by chance have hdr enabled?
im seeing crashes as well with hdr enabled on my primary screen. auto hdr off still games are crashing.
turned off hdr and games dont crash
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
We understand that you are having crashing issues in multiple games. As we promised earlier, we will continue to assist you with the Far Cry 6 issue in this thread. Please note that we will be replicating the crashing issue internally and will update you as soon as we have more information.
To ensure that this thread remains organized, we kindly request you create a separate thread for any other issues you may be facing. We appreciate your cooperation and look forward to resolving your concerns.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
We want to let you know that we tried to replicate the issue you described internally; however, we have not been able to replicate your issue. We have been able to play the games without crashing. We invite you to check the following videos of our lab process to see if see that something is missing. It is important to mention that we only recorded the last minutes of gameplay and we played the games for about 15 minutes:
Based on this information we would recommend you to run the Display Driver Uninstaller to eliminate all previous driver leftovers and install the new driver 31.0.101.4952.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This card is **bleep** man.. Now i wont get my money back..Now i am faccing crash on dying light 2. I am facing game crash in every single game. I cant tolerate this..When willl you fix the problem..If you cant solve stop selling the cards. I am using latest driver
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Himel,
We understand that you are experiencing crashing issues while playing games. We know how frustrating it can be and we are sorry for the inconvenience. We would like to help you solve the problem, but we need your cooperation to provide more details about the issue.
Bandit8623 mentioned a similar issue with HDR enabled. Is this related to your issue? Are you using HDR when playing games?
We noticed that you are using the latest driver, but we want to know if you tried running the DDU software. This will help eliminate the possibility of corrupted files from previous driver versions that may still be present in your system. Although we were unable to replicate your issue, we have shared video files for you to review in case you notice anything that we may have missed during our testing.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Bandit8623,
Thank you for joining this thread to report that you are experiencing a similar Problem. If you want, you can stick to this thread and check if there are any recommendations that you haven't tried. However, we invite you to open a new thread so you can have personalized troubleshooting for your issue.
Best regards
Jean O.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have no hdr enabled..i have given you all details previously.. just fix the problem..i cant open thread for all games.. i have work to do
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Looking from the outside in you are being rude. And you haven't answered Intel questions. I'll post again so you can answer them.
"1-Which distribution service do you use to install the Far Cry 6 game? We would like to know the options you used for all three games. (Steam, Epic Games, Microsoft Store, Xbox Store)
2-Did you have another graphics card before you installed the Intel Arc graphics adapter? Sometimes, files from previous graphics cards can cause the new adapter to not work as expected, so we want to discard this possibility.
3-Were you able to discard the run of the DDU tool? Remember that this suggestion is based on the idea that there may be corrupted files from previous driver installations that can affect the new driver and impact system stability
4-Finally, we would like to know if there is anything special that triggers the crashing issue. Maybe the issue is related to a game location or even action. Therefore, we would like to ask if there is a particular step to replicate the problem. You previously mentioned that the issue occurred after playing for some time, but we would like to know if there is anything else you have noticed lately."
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
