Intel® ARC™ Graphics
3331 Discussions
Installation problem
David4312
My asrock Intel ARC a380 challenger ITX is not working properly its plugged in and everything but my computer screen won't turn on
Senkuchan
Valued Contributor II
I suggest that you check out these articles for some helpful steps:
https://www.intel.com/content/www/us/en/support/articles/000092760/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000094366/graphics.html
Could you also share the make and model of your motherboard, processor and power supply wattage?
David4312
Found out that the 6-8 prong power supply was not plugged it
Senkuchan
I see. That’s why. Meaning, everything is working fine now? Right?
David4312
Well I'm not really allowed to open the case parents
David4312
Ok so is the graphics supposed to come with a 6-8 pronged power connecter
佑綺_Mayu
The 8+6 power connector comes from the power supply, normally the 8 pin is split into half (2 4 pins but it has a connection) and the 6 pin is 2+4 (like the 8 pin it has a connection as well)
David4312
So the power supply with my PC is that it is hidden
Senkuchan
If your power supply is hidden, it means that it is either built into the case or mounted behind a cover or a shroud. This can make it difficult to see the model and specifications of the power supply without opening the computer.
