Intel® ARC™ Graphics
3294 Diskussionen
Intel Arc A750: Issues with game "Counter-Strike 2"
jxn
Neuer Beitragender I
7.938Aufrufe
Hi, I'm reopening a recent post I made when CS2 was still in beta, and was advised to wait until the full release, and to then reopen this thread if the issue persisted after release.
My issues consist of graphical glitches when loading into games (premier mode/matchmaking/practice), and it seems very inconsistent because these glitches don't happen every time (but still most of the time). The glitch itself is a partly frozen screen, except for the mini-map and other hud elements, e.g time, and game sounds, which work normal.
What I have done to remedy this frozen screen is to have closed the application and relaunched from the steam launcher, which becomes quite the hassle to have to do nearly every game I play.
This seems to be happening only on my system, as my friend don't own Intel graphics in their PCs, and run the game effortlessly. I lean towards it being a driver issue on the A750, but I can't be sure.
Beschriftungen (3)
1 Lösung
Hugo_Intel
Mitarbeiter
7.090Aufrufe
Hello jxn
It seems at the moment no other community member is looking to report crashes on CSGO2 so following our previous recommendation, it would be better to check with Valve or to wait for them to continue patching the game and improving its stability, however, in case any other issues come up and you have the steps to reproduce the problem we will be more than willing to continue testing this game. We know this is a very popular title and will be happy to help.
This thread will no longer be monitored, but as stated above do not hesitate to open a new topic if you need further assistance.
Hugo O.
Lösung in ursprünglichem Beitrag anzeigen
16 Antworten
Hugo_Intel
Mitarbeiter
7.849Aufrufe
Hello jxn
Thank you for posting on the Intel® ARC™ Graphics Communites. We appreciate your getting back to us and bringing this graphic glitch issue to our attention.
We would like to suggest a couple of steps to ensure the best compatibility and discard any possible corrupted installation of the driver, please let's try the following:
  • Based on your SSU log you already have the latest driver installed, so let's try a reinstallation by using Display Driver Uninstaller to uninstall the driver. After the driver has been uninstalled reinstall it on your system. If you have already done these steps just let us know, no need to redo it.
  • Let's also try to get your BIOS updated to the latest version to ensure the best compatibility with the GPU. Visit your motherboard manufacturer's website and update to their latest version which should be 2801.
If the same issue still happens after the above steps we might need to test this problem from our side, in that case, we would like to get the in-game graphics settings you are using so we can test in the same conditions, if possible to share a screenshot it would be better.
Along with the in-game graphics settings, we would like to know the exact steps to reproduce the problem, From what I see in your post this happens when getting into the different game modes but should the issue happen right after loading the game mode or during regular gameplay.
Hugo O.
Andres_Intel
Mitarbeiter
7.780Aufrufe
Hello jxn,
Were you able to try a reinstallation by using Display Driver Uninstaller and try to get your BIOS updated?
Andres P.
jxn
7.736Aufrufe
Yes, I did update the motherboard bios and did a clean install of the gpu drivers with DDU. However I noticed that the game started running smoother without these glitches when loading into games prior to me updating my bios and drivers. This issue was then probably addressed in a game update by Valve.
Then again now I have started to come across inconsistent game performance since updating my bios and reinstalling drivers in the form of random game crashes. I have updated my drivers since my original post to the .4885 driver version, but I am still experiencing game crashes.
Andres_Intel
Mitarbeiter
7.704Aufrufe
Hello jxn,
Thank you for your response and for all the information provided, it has been really helpful.
Please answer the following questions, which are going to help us in case with need to start with a case replication:
  • Take screenshots of the game settings.
  • Provide step-by-step instructions, if possible a video on about to reproduce it
Andres P.
jxn
7.673Aufrufe
Here I have attached screenshots of my in-game settings that I have encountered these issues with. As I previously tried to explain, this behaviour seems very inconsistent, and I could therefore not replicate a game crash.
I speculate it has something to do with molotov grenades being extinguished by smoke grenades, as it seems to occur during this kind of situation in-game. Though I could not recreate this on my own in a private match, but I did observe a sizeable drop in FPS during this action (from around 220 to around 140).
Hope this will help.
Hugo_Intel
Mitarbeiter
7.643Aufrufe
Hello jxn
Just to make sure from what I understand from your previous posts, the main, original issue which was a partially frozen screen is not happening anymore but now there are random crashes that seem related to Molotov Grenades, Is this a good summarization of the situation?
Also, there has been a new driver update version 31.0.101.4887. Please let's retest with the new version and check if the same issue still happens. If possible as previously advised continue to use Display Driver Uninstaller before updating to the new version.
Hugo O.
jxn
7.612Aufrufe
Yes, that about sums up the extent of my issues with the game. I have also updated to the newer .4887 driver, but the crashes still persist.
Hugo_Intel
Mitarbeiter
7.590Aufrufe
Hello jxn
Thank you for clarifying and confirming the issue still happens after testing driver 4887. Let us take a look at this issue and check if we might be able to reproduce it. We will let you know once we have more information.
Hugo O.
Hugo_Intel
Mitarbeiter
7.448Aufrufe
Hello jxn
We wanted to give you an update on this issue and a couple of recommendations as well. We have been testing this game in multiple multiplayer matches and tried also with the Molotov Grenades, however, we have not been able to reproduce any crashing behavior so far and the game has been working fine without issue.
Please let's try updating to our latest driver version 31.0.101.4900 using the DDU method we shared in previous posts, and make sure to update the game to the latest version since Valve has released a few updates since our last post. In case the issue continues to happen after updating the game, we would advise that you uninstall completely, redownload, and reinstall the game to make sure the issue is not caused by a corrupted game file.
Hugo O.
Hugo_Intel
Mitarbeiter
7.347Aufrufe
Hello jxn
I wanted to check if you had the chance to retest the game with our latest driver or if you have reinstalled the game on your system. Please let us know if the issue is still happening. Check a video of the tests we have done so far in the following link https://www.youtube.com/watch?v=ZMwpcxx7WJc, however, as informed in our latest post we have not been successful in reproducing this issue.
Hugo O.
jxn
7.301Aufrufe
Yes I am still experiencing occasional game crashes when playing online matchmaking, although it definitely seems to occur less now. This maybe could have something to do with valve further optimizing the game in recent updates. I especially felt an improvement after an update where gun muzzle flashes were optimized and improved in-game, which leads me to believe that it might have to do with game optimization instead of hardware or driver related issues.
To clarify, the measurements I took towards improving this issue were updating graphics drivers (also reinstalling after DDU uninstall), updating the game and also reinstalling the game, which significantly decreased, although didn't eliminate, game crashes.
Cheers!
jxn
7.299Aufrufe
I would also like to add that I have heard from some friends who I play with, that they are also experiencing occasional game crashes on other gpu manufacturers cards (AMD and NVIDIA) while playing online matchmaking. This would further emphasize my suspicion that this indeed is a problem with game optimization rather than driver related issues.
If that is the case, then I completely understand that this would presumably be something that you can't address, and that I will have to patiently wait for further optimization in future game updates from Valve.
Thank you anyways for trying to help to the best of your capabilities!
Hugo_Intel
Mitarbeiter
7.236Aufrufe
Hello jxn
I see the crashes are still happening from your side. Based on what you are saying, if other users are experiencing this problem on third-party GPUs it might as well be a game issue that needs to be optimized and the crashes seem to be random which makes the reproduction of the problem a little bit difficult since we did not see it from our side, however, allow me to check with our team to see if there is anything else that we can do from our side.
Hugo O.
Hugo_Intel
Mitarbeiter
7.210Aufrufe
Hello jxn
I reviewed this problem with our team and at the moment the best recommendation would be to continue checking with Valve for further support/troubleshooting since we suspect this is a game issue rather than driver related, however, we will make a post at the top of the thread to ask other users if they are experiencing a similar situation so if any other users report the problem we can gather more information so we will continue to monitor this thread for a few more days.
Hugo O.
Hugo_Intel
Mitarbeiter
7.210Aufrufe
Hello everyone
If any user is experiencing random crashes or crashes in a specific situation when playing CSGO2, please reply or comment to this post/thread so we can gather more information. At the moment we believe the issue to be more game-related but we are more than willing to gather information and do more testing since this is a very popular game. So feel free to comment, note this thread is only related to crashes if there is any other issue with the game, please open a new thread.
Hugo O.
Hugo_Intel
Mitarbeiter
7.091Aufrufe
Hello jxn
Hugo O.
Antworten
