Intel® ARC™ Graphics
3394 Discussions
Intel Arc Driver Quantization Range Error
bronze
The quantization range on my Intel Arc graphics card reverts to default after rebooting, even when I set it to Full. This issue started with driver 6874 and persists with the new 6876 driver. It doesn't appear with driver 6737
cpu 12400f
mb asus h610m a d4
ram 16gb*2
power 550w
ssd 512gb nvme
Gabriela_Intel
Thank you so much for your patience. I'd like to inform you that this is fixed in the latest version of the Intel Graphics Software (25.30.1705.2). Please install the latest driver with IGS and let us know if this resolves the issue for you.
Thanks!
Gabriela E.
JeanetteC_Intel
Hello bronze,
To better understand the issue and provide an effective recommendation, please provide the following key information:
  1. Share a short video demonstrating the issue.
  2. Does the issue occur with driver version 32.0.101.6790 (WHQL Certified)? Please try a clean installation using Display Driver Uninstaller (DDU) and check if the problem persists.
  3. Is this happening with the Intel® Graphics Control Panel, Intel® Graphics Command Center, or Intel® Graphics Software?
Additionally, I would greatly appreciate it if you could share your system configuration so I can thoroughly assess and offer an accurate solution. You can do this by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  1. Scan: Check the box Everything.
  2. Click Scan.
  3. Review: When finished scanning, click Next.
  4. Click Save. *Attach the SSU log file as you reply.
JeanetteC.
bronze
Does the issue occur with driver version  32.0.101.6790 (WHQL Certified)? => yes
Please try a clean installation using  Display Driver Uninstaller (DDU) and check if the problem persists.=>I always use DDU in safe mode to clean install new drivers.
Is this happening with the Intel® Graphics Control Panel, Intel® Graphics Command Center, or Intel® Graphics Software?=>Yes, that's right. Driver versions 6790 through 6876 have a recurring issue where the quantization range defaults to an incorrect setting
I'm encountering a consistent bug across two PCs (A380 and A310) where the quantization range defaults incorrectly with Intel driver versions 6790-6876. Importantly, driver 6737 does not show this behavior on either system. This strongly suggests a defect in Intel's latest drivers.
JeanetteC_Intel
Hello bronze,
We have recently uploaded new driver, version 32.0.101.6877 for Intel® Arc™ A-Series Graphics. Kindly proceed with a clean installation using Display Driver Uninstaller (DDU).
Please also share a short video demonstrating the issue, if the issue still persists.
JeanetteC.
bronze
The problem continues with the new driver as well.
  • "Full" Video: "The 'Full' video shows the driver installation process and then changing the quantization range to 'Full'."
  • "Reboot" Video: "The 'Reboot' video demonstrates that after rebooting, the quantization range reverts to 'Default'."
JeanetteC_Intel
Hello bronze,
Thank you for sharing this update. I will keep investigating the issue and will provide an update on the community thread as soon as possible.
JeanetteC.
JeanetteC_Intel
Hello bronze,
Please review the private message sent to your email for the update. Be sure to check your inbox, as well as your spam and junk folders, as the message may have been directed there.
JeanetteC.
JeanetteC_Intel
Hello bronze,
Please be advised that we've filed a bug report on the issue with the Quantization settings.
I'll provide an update as soon as the issue has been resolved.
JeanetteC.
bronze
Since my bug report on June 5th, this issue has persisted consistently across driver versions from 6739 to 6972, excluding 6734 and 6737. There has been absolutely no improvement, and it's frustrating that the latest drivers still exhibit this problem.
Do you genuinely believe this issue is less critical than specific game bugs? Having a core display setting like Quantization Range reset to default every time I reboot causes significant inconvenience.
Currently, if I use the system without launching the Intel Graphics Software (IGS), the setting remains stable. However, the moment I launch IGS and simply navigate to the 'Display' tab, the setting immediately reverts to default. This forces me to manually reconfigure a crucial setting every single time I want to access driver options, which is incredibly disruptive to my workflow.
Isn't this a fundamental, 'bread and butter' driver function that should just work? I've used NVIDIA and AMD cards extensively, and I've never encountered such an issue with their drivers.
Are you perhaps under the impression that 'it's just a single click to change it back to Full Range, so it's not a priority to fix'? I must question this seemingly nonchalant attitude towards user experience, which appears to be why this basic bug hasn't been resolved for months. You confirmed that you successfully reproduced this bug in my initial report, so why is it still absent from the 'Known Issues' list?
Gabriela_Intel
This issue is still open and actively being investigated. We handle a wide range of issues, each with its own priority, and we're committed to balancing these priorities to resolve issues as quickly as possible.
Regarding the Known Issues list, not every issue is included in the Release Notes. However, even if your issue isn't listed, please rest assured that we are taking it seriously.
Thank you for your patience and understanding. I really do apologize for the inconvenience.
Gabriela E.
AbdulJami
This quantization reset issue is likely a driver bug in versions 6874 and 6876. Since it works fine on 6737, you might want to stick to that older driver until Intel releases a fix. Also, keep an eye on future driver updates.
Gabriela_Intel
Thanks!
Gabriela E.
bronze
Gabriela_Intel
Awesome, thanks for confirming! I'll close out this thread then.
Gabriela E.
