Intel® ARC™ Graphics
3296 Discusiones
Performance Intel Arc A770
addelucas123
Nuevo Colaborador II
48.867 Vistas
Goodnight
I am David and I have come to say that it will improve the performance of the Intel Arc A770 graphics card through the drivers to compete with RTX 3060 TI, you must exceed at least 10%, that is, Arc A770 exceed 10% of the RTX 3060 Ti and catch up with the RTX 3070.
Sorry to bother you, I'm just saying this because I'm watching a performance video.
Cheers
0 kudos
49 Respuestas
LuisGustav_A_Intel
Empleados
19.368 Vistas
Hello David1997,
Thank you for contacting Intel Technical Support for graphics.
We understand your desire to have performance upgrades through drivers against market counterparts while using Intel® Arc™ A770 Graphics. We are glad to assist.
  1. Please provide the link review you watched for a point of comparison, and probably highlight the main differences.
  2. If you own an Intel® Arc™ A770 Graphics card already, may I know if you present a problem in terms of performance, or errors with a particular program? If so describe it and provide steps completed.
Please download, run and reply back attaching the .txt file of the tool Intel® System Support (For download visit https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?product=91600 ).
Luis A.
addelucas123
19.346 Vistas
Check if everything is fine and working correctly thanks
Kushikush
Novato
18.932 Vistas
Having issues with Google Chrome being laggy, and also the max fps in league being to low, regardless thanks for updating the drivers, im sure you will do great,
addelucas123
18.914 Vistas
I have everything updated and I don't use chrome while I play and it can't be slow because I have 32GB of RAM and an i7-11700K is the latest activated Resizable BAR
nativemick
Principiante
15.263 Vistas
nativemick
Principiante
15.262 Vistas
This is what I see now.
LuisGustav_A_Intel
Empleados
19.299 Vistas
Hello David,
Thank you for the Intel® System Support report. So your Intel® Arc™ A770 Graphics uses the latest version of the driver available.
https://www.intel.com/content/www/us/en/download/726609/intel-arc-graphics-windows-dch-driver.html
About the motherboard, Asus has a higher version of BIOS respecting system stability you may want to consider, if you plan to change it, please follow their instructions.
https://rog.asus.com/motherboards/rog-strix/rog-strix-z590-f-gaming-wifi-model/helpdesk_bios/
For additional support, recall the earlier questions to investigate it.
May I know if you require additional support?
LuisGustav_A_Intel
Empleados
19.261 Vistas
Hello David1997
Upon checking wonder if you made any additional changes and would like to know if you need further assistance?
Luis A.
addelucas123
19.250 Vistas
yes of course but fix the problem with drivers, from red dead redemption 2 DX12 1 FPS since when I put 144Hz it gets 50Hz and that is drivers and improve performance more to surpass Intel Arc A770 to the RTX 3060 TI between 5% and 7% please
addelucas123
19.246 Vistas
good morning
I could fix the implementation of Intel XeSS technology for red dead redemption 2 why rockstar does not guarantee implementation by users and players should kindly contact Intel developer engineers to implement that XeSS RDR2 technology
LuisGustav_A_Intel
Empleados
19.201 Vistas
Hello David1997,
Thank you for the comments, I am glad to hear you managed to solve the red dead redemption 2 performance concern.
About the rest, I can submit the information but can't commit to a particular outcome/deadline/provide updates though.
May I know if you have other concerns?
Luis A.
LuisGustav_A_Intel
Empleados
19.142 Vistas
Hello David1997,
Upon checking your post, and would like to know if you need further assistance?
Luis A.
addelucas123
19.130 Vistas
good morning
I'm David, I've come to report drivers performance problem DirectX 12 Red Dead Redemption 2 1 FPS ultra quality remains games are going well I need you to fix the problems and cyberpunk 2077 if I put Ray Tracing ultra by default 25 to 30 FPS and if I put only ultra 40 to 60FPS, With the kindness that the superior engineers have it next drivers
regards
David
LuisGustav_A_Intel
Empleados
19.118 Vistas
Hello David1997,
Make you the configuration at the bios level is correctly configured. You may check Intel® Arc™ A-Series Graphics – Desktop Quick Start Guide https://www.intel.com/content/www/us/en/support/articles/000091128/graphics.html , things like resizable bar improves games performance overall.
Luis A.
addelucas123
19.115 Vistas
Goodnight
I'm sending you the screenshots so you can see that everything is activated. I'm sorry, some things will be in Spanish and another in English, but everything is activated, check GPT hard disk format and I have it configured like this, let's go as it came to me.
addelucas123
19.115 Vistas
What happens is that only red dead redemption 2 works for me at 1 FPS but the other games don't and rockstar says it's not a game problem so they can't help me at all. My motherboard model is ASUS STRIX ROG Z590-F GAMING, i7-11700K and finally a DDR4 3200MHz 32GB ram memory module and a corsair RM850 80 Plus Gold Modular power supply
addelucas123
19.113 Vistas
addelucas123
19.110 Vistas
As you can see, everything is activated, configured and also with the latest version there is no problem with computer hardware, I know that it is 100% real drivers because red dead redemption 2 throws 1 FPS at me in DirectX 12 and the rest is going well. drivers are missing, I want a report but implement the following update that improves all DirectX 10, 10.1, 11, Vulkan and 12 APIs, correct stability and performance experiencing problem when activating DirectX 12, Please I am a customer with you and I don't want to have a performance problem, I've already had a problem with NVIDIA, for now it would be Intel to work with you, improve, especially try to correct stability and performance when activating DirectX 12, as in my case Red Dead Redemption 2 OK PLEASE!
LuisGustav_A_Intel
Empleados
19.050 Vistas
Hello David1997,
Thank you for the information.
Definetely if there are improvement oportunies, we want to take advantage of and provide ongoing support.
Let me ask the following about the red dead redemption 2 game, which distribution game service used, Quality (Low, Medium, High, Ultra), resolution, Vsync (on/off), Display (Fullscreen/ Windowed / Borderless Windowed), game version, steps for reproduction regarding the directx12 activation you are affected in performance, game mode story/online, and any important details you consider about this/ screenrecording capture for internal investigation purposes.
If you dont mind, please generate an updated Intel® System Support report.
Luis A.
LuisGustav_A_Intel
Empleados
18.896 Vistas
Hello David1997,
I was checking your case and would like to know if you need further assistance?
Please test new drivers and provide update about your previous reported problems
Intel® Graphics Driver 31.0.101.3959 (download go to website https://www.intel.com/content/www/us/en/download/726609/intel-arc-graphics-windows-dch-driver.html )
Intel® Graphics Beta Driver 31.0.101.3975 (download go to website https://www.intel.com/content/www/us/en/download/729157/intel-arc-graphics-windows-dch-driver-beta.html )
If the problem persists,
Please generate an updated Intel® System Support report.
Luis A.
Responder
