- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
When I play with FSR in Red Dead Redemption 2 the game looks weird I don't know how to explain it that's why I send a video.
When I was using a Nvidia GPU this didn't happen even with the same game version and updated drivers and the same operating system (Windows 10).
The FSR problem is the same even if I change it to quality, balance and performance
- タグ:
- FSR issue
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello TheRitrax,
Thank you for posting on the Intel
To have a better understanding of the situation, please answer the following questions:
- Take screenshots of the game settings, in case we have to replicate the issue.
- Did this happen before? Did the issue happen after and update?
- Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows, to check if there is a pending update and know your system information.
Andres P.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Ok, this is the log (I ran the Intel® System Support Utility and performed the analysis while I had Red Dead Redemption 2 open and FSR 2.0 enabled.)
- Take screenshots of the game settings, in case we have to replicate the issue. Ok
- Did this happen before? Did the issue happen after and update? With Nvidia GPUS no but with Intel GPUS yes
- Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU) , you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows, to check if there is a pending update and know your system information.
Ok
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello TheRitrax,
Thank you for your response and for all the information provided it has been really helpful.
I see you have attached some screenshots showing the issue that you have, we also need screenshots showing the display game settings, this is for replicating the issue as accurate as possible, in case that we need it.
Please follow the steps below and let me know the results:
- Clean install the graphics driver to version 31.0.101.4669 with Display Driver Uninstaller (DDU). For guidance, How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
Andres P.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello TheRitrax,
Were you able to clean install the graphics driver to version 31.0.101.4669? This is a driver we released the last week and I want to make sure if the behavior changes after the clean installation.
Andres P.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello TheRitrax,
We have not received a response from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
