Intel® ARC™ Graphics
3329 토론
Refresh rate problems, Intel ARC B580
Drakkar
초급자
1,482 조회수
Bem, eu atualizei recentemente. Eu tinha um GTX1060 6 GB, o que me dava 144 Hz a 1920x1080 no meu monitor; no entanto, com minha recente compra do Arc B580, usando o cabo Ugreen HDMI 2.1, ele está me dando apenas 60 Hz a 1920x1080. Baixei o DDU para desinstalar drivers gráficos antigos, instalei os Intel e nada mudou; Eu ainda tenho meus 60 Hz.
Meu monitor é um GN246HL ACER, com entradas HDMI, VGA e DVI.
0 포인트
6 응답
RandyT_Intel
중재자
1,394 조회수
Hi @Drakkar,
Informamos que só posso apoiá-lo em inglês. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Have you tried installing the latest BIOS on your computer?
  • Are you using a direct connection, or are you using video adapters, converters, or a docking station?
  • Have you tried using a different HDMI cable?
Warm regards,
Randy T.
0 포인트
Drakkar
초급자
1,359 조회수
1° OK
2°Yes, I have the latest version. I have an MSI PRO B650m-p.
3° Yes, I'm using it that way.
4° Yes.
0 포인트
RandyT_Intel
중재자
1,327 조회수
Hi @Drakkar,
Can we try this step, Install the latest Display's INF file for your display.
    • Some displays will require an update to their firmware. Consult with your display manufacturer for instructions on how to update it.
Randy T.
0 포인트
Drakkar
초급자
1,315 조회수
I think I've "discovered" the problem, as I said, my monitor has HDMI, DVI and VGA inputs. It seems that the monitor only delivers 144hz over DVI, which seems strange to me, but I think the problem is with my monitor.
Thanks for your attention.
0 포인트
RandyT_Intel
중재자
1,254 조회수
Hi @Drakkar,
Thank you for the update. I'm glad to hear you've identified the potential issue with your monitor's input settings. It does seem unusual that the monitor only delivers 144Hz over DVI, but it's good to know where the problem might be.
May I ask if you still need further assistance from my end?
Randy T.
0 포인트
RandyT_Intel
중재자
1,153 조회수
Hi @Drakkar,
I wanted to provide you with an update regarding your previous concern. We recommend using a direct cable connection for improved display quality and performance. For more information, please refer to our article titled "Using Video Cable Adapters, Splitters and/or Docking Stations in..." This article provides valuable insights into optimizing your setup.
I will be closing this inquiry. If you require further assistance, please submit a new question, as this thread will no longer be monitored.
Randy T.
0 포인트
응답
