Intel® ARC™ Graphics
3328 Discusiones
Refresh rate problems, Intel ARC B580
Drakkar
Principiante
1.480 Vistas
Bem, eu atualizei recentemente. Eu tinha um GTX1060 6 GB, o que me dava 144 Hz a 1920x1080 no meu monitor; no entanto, com minha recente compra do Arc B580, usando o cabo Ugreen HDMI 2.1, ele está me dando apenas 60 Hz a 1920x1080. Baixei o DDU para desinstalar drivers gráficos antigos, instalei os Intel e nada mudou; Eu ainda tenho meus 60 Hz.
Meu monitor é um GN246HL ACER, com entradas HDMI, VGA e DVI.
0 kudos
6 Respuestas
RandyT_Intel
Moderador
1.392 Vistas
Hi @Drakkar,
Informamos que só posso apoiá-lo em inglês. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Have you tried installing the latest BIOS on your computer?
  • Are you using a direct connection, or are you using video adapters, converters, or a docking station?
  • Have you tried using a different HDMI cable?
Warm regards,
Randy T.
Drakkar
Principiante
1.357 Vistas
1° OK
2°Yes, I have the latest version. I have an MSI PRO B650m-p.
3° Yes, I'm using it that way.
4° Yes.
RandyT_Intel
Moderador
1.325 Vistas
Hi @Drakkar,
Can we try this step, Install the latest Display's INF file for your display.
    • Some displays will require an update to their firmware. Consult with your display manufacturer for instructions on how to update it.
Randy T.
Drakkar
Principiante
1.313 Vistas
I think I've "discovered" the problem, as I said, my monitor has HDMI, DVI and VGA inputs. It seems that the monitor only delivers 144hz over DVI, which seems strange to me, but I think the problem is with my monitor.
Thanks for your attention.
RandyT_Intel
Moderador
1.252 Vistas
Hi @Drakkar,
Thank you for the update. I'm glad to hear you've identified the potential issue with your monitor's input settings. It does seem unusual that the monitor only delivers 144Hz over DVI, but it's good to know where the problem might be.
May I ask if you still need further assistance from my end?
Randy T.
RandyT_Intel
Moderador
1.151 Vistas
Hi @Drakkar,
I wanted to provide you with an update regarding your previous concern. We recommend using a direct cable connection for improved display quality and performance. For more information, please refer to our article titled "Using Video Cable Adapters, Splitters and/or Docking Stations in..." This article provides valuable insights into optimizing your setup.
I will be closing this inquiry. If you require further assistance, please submit a new question, as this thread will no longer be monitored.
Randy T.
Responder
