Intel® ARC™ Graphics
3371 Discussions
Variable refresh rate support
Matyugovich
Will there ever be VRR support via HDMI 1.4? There are lots of cheap 1080p IPS VRR 100-120Hz monitors, but you cant use them with Intel GPU.
RamyerM_Intel
Hello Matyugovich,
Thank you for posting in the communities. To answer this more specifically for you, may I please know the Intel GPU that you use and the monitor that you are considering? I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello Matyugovich,
I am just following up regarding the model of your GPU and monitor that you are considering. This way we can be more detailed with our answers. I will be waiting for your reply.
Ramyer M.
Matyugovich
I have Sparkle Arc A580 and ASRock CL27FF monitor
RamyerM_Intel
Hello Matyugovich,
Thank you for sharing this details and I would like to apologize for the delay in my response. Upon checking this specifications, I can confirm that HDMI 1.4 does not support Variable Refresh Rate. In order to use the VRR, the HDMI input display must be a  2.1 standard and should also support VESA Adaptive Sync .
You may also visit this article as reference : Variable Refresh Rate (VRR) 'Not Supported' in Intel® Arc™ Control
Ramyer M.
RamyerM_Intel
Hello Matyugovich,
I am just checking in if you additional questions. Feel free to reply to this post so we can answer them for you. Thank you.
Ramyer M.
