Intel® ARC™ Graphics
3379 Discussions
a750 open resizable bar instead lower fps
Timsir527
When I don't turn on the resizable bar, the fps can reach 130~140, and the gpu usage can reach 90+, but after turning it on, the fps is left in the 70s, and the gpu usage is left 50~60.
My device
cpu amd r5 4500
motherboard gigabyte b550m aorus elite
gpu arc a750
ram umax 32g(8gx4)ddr4 3200
rog 550w
Timsir527
Mike_Intel
Hello Timsir527,
Thank you for the reply.
I am sorry if I have to be ask you to resend the screenshot and kindly convert the characters to English in your APEX app.
This should help us and our Engineers to check the settings. If you can also provide some steps on how did you change the settings on this app, that would be helpful as well.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Timsir527
Mike_Intel
Hello Timsir527,
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Michael L.
Donaldgallo
Enabling resizable BAR on your system, featuring an AMD R5 4500 CPU, Gigabyte B550M Aorus Elite motherboard, and an ARC A750 GPU, seems to lead to a decline in performance, dropping FPS to the 70s with GPU usage at 50-60%. To address this, update BIOS and GPU drivers, check for resizable BAR support and recommendations from manufacturers, explore BIOS settings, and experiment with different configurations. If issues persist, seek guidance from community forums or customer support for your motherboard and GPU. It's crucial to find a balance that optimizes resizable BAR functionality without compromising overall system performance.
Timsir527
But this problem only occurs in apex legends
Timsir527
I found that r5 4500 only supports pcie3.0. Is this possible reason?
Mike_Intel
Hello Timsir527,
I tried checking the specification of ARC A750 and it supports Up to PCI Express 4.0 x16.
So checked the link below and found that Ryzen 4000 series is not listed.
https://www.intel.com/content/www/us/en/support/articles/000096161/graphics.html
Michael L.
Mike_Intel
Hello Timsir527,
Michael L.
Mike_Intel
Hello Timsir527,
I am sending another follow up to check if you still have questions or clarifications.
Michael L.
