Intel® Arc™ Discrete Graphics
3521 Discussions
Problem using Handbrake and B580
Laroldski
When I encode video's with HandBrake when using my ASROCK B580 card and what happens is the encoding will stop for no reason and HandBrake from what I remember doesn't show any error's and it's almost like the encode was successful.
I noticed when using  the version below is where I started to having problems.
32.0.101.8135
32.0.101.8136
32.0.101.8247
I reverted back to 32.0.101.7028 because I wasn't 100% certain when the problem started happening as I update every time a new ARC Driver comes out.
I'm going to install 32.0.101.8147 again and see exactly what happens with HandBrake,when the problem happened it happened around 1 out of every 4 to 8 encodes would be my best guess.
Once I start having the problem again I will update this thread,just to be clear I have yet to have an encode fail while using driver version 32.0.101.7028
If any Mod's that read this thread can you please let me know if this is a known problems with the newer ARC drivers.
Laroldski
@KennethB_Intel I just got done installing Windows and updating everything and this time and the last time when I ran HandBrake I was also running fully up to date Windows 11 25H2.
In Task Manager the gpu was running at 71 to 79% this time and I was running Arc Driver 32.0.101.8250
KennethB_Intel
Hello Laroldski,
Thank you for your response. Please allow me to further check this internally. I'll get back to you as soon as possible.
Kenneth B.
Laroldski
@KennethB_Intel  I just had another video fail while encoding it using HandBrake and the latest Intel ARC driver and I'm attaching the Log to this message.
KennethB_Intel
Hello Laroldski,
We will attempt to recreate the issue on my end; however, to ensure accurate testing, could you please share screenshots or a screen recording of the exact settings you are using?
This information will help us reproduce the issue precisely and provide the most effective assistance.
Kenneth B.
Laroldski
@KennethB_Intel  I included the custom Preset File that I use for HandBrake,just import the file into HandBrake and it will be the only one under custom.
I can say how many times you may have to keeping retrying to encode a file to get a failure as I have done 50 to 60 encodes sometimes and I don't get a failure and then I can get 1 to 3 fails out of 12 or 15 encodes for whatever the reason.
I put the file in a zip file because the uploader for this forum did allow it the uncompressed file to be uploaded.
I also forgot to mention before and I don't know if this will make any difference but I also under the Preferences check off where it say say's Enable Low Power Quicksync Hardware and that's it under that tab.
Under Preferences for Work Priority Level I set that to High.
I also included screen shots as well.
