Hi...
Recently, I downloaded the Intel Collaboration Suite for WebRTC Client SDK for Windows.
But, I have a problem.
I cannot compile because sioclient_tls.lib.
The sioclient_tls.lib is being referenced by the sample project, I cannot find this library.
Where to find "sioclient_tls.lib"?
Thank you.
- Tags:
- HTML5
- JavaScript*
有关sioclient_tls.lib,如有需要请联系我
顺别也跟你交流下我碰到的问题,对我的问题看看能否有解
谢谢
Hi sanghoon,
We do not provide the siocket_tls.lib in our release package. If you need it, please compile it from the source code.
Thanks!
Hi, in this docs you're saying that
The sioclient_tls.lib included in release package has been enhanced to verify server's certificate. Handshake fails if the server is using an invalid certificate.
https://software.intel.com/sites/products/documentation/webrtc/windows/index.html
I didn't find any sioclient libs in the latest release.
Please, give us a hand here, where can we find this lib files?? If the docs are wrong, please fix them , but it'll be great if we can have this as part of the release.
Regards.
M.
Hi, I have the same problem as Martin A.
You mention in the documentation that there are modifications in sioclient_tls.lib but the file is not part of the release. Is it possible to give a hint what modifications where made so that I can compile the library from source?
Thanks and best regards
Markus
this is a problem of socket.io-client-cpp, check the github code https://github.com/socketio/socket.io-client-cpp/blob/master/CMakeLists.txt#L49-L51, if you install openSSL, then sioclient_tls.lib will be built.
![](/skins/images/44D6FBC13D1AFC21DF3F0C7813903D74/responsive_peak/images/icon_anonymous_message.png)
