Good morning,
Since yesterday whenever I try to compile for FPGA hardware I get an error related to Quartus. I have tried to generate a report and emulate the design and all that works fine. However when I do the hardware compilation I get this error:
$ dpcpp -fintelfpga -Xshardware -Xsboard=/opt/intel/oneapi/intel_a10gx_pac:pac_a10 -Xsread-only-cache-size=2048 *.cpp
aoc: This compilation stage requires an installation of Intel(R) Quartus(R) Prime software!
aoc: However Quartus was not found on the PATH or passed in using QUARTUS_ROOTDIR_OVERRIDE.
aoc: If you have a valid installation, please pass it in using QUARTUS_ROOTDIR_OVERRIDE or add it to the PATH.
aoc: Otherwise, consider downloading Quartus from here: https://www.intel.com/content/www/us/en/software-kit/661712/intel-quartus-prime-pro-edition-design-software-version-19-2-for-linux.html
llvm-foreach:
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
I checked Quartus installation and it seems to be installed in /opt/intel/intelFPGA_pro/19.2/quartus so I tried adding it to the PATH but it also didn't work. It generates a report and then says the hardware generation failed.
Is there anything I should do to fix this?
Hi All,
Please try the following workaround:
$ QUARTUS_ROOTDIR_OVERRIDE=/opt/intel/intelFPGA_pro/19.2/quartus <make_or_cmake_command>
The idea is to set the environment variable manually.
For future reference, the QUARTUS_ROOTDIR_OVERRIDE env var should not be empty and should point to the latest installation of Quartus.
$ echo $QUARTUS_ROOTDIR_OVERRIDE
If this resolves your issue, make sure to accept this as a solution. This helps others with similar issue.
Alekhya
Check out the answer I wrote on another recent post: https://community.intel.com/t5/Intel-DevCloud/Quartus-not-install-on-fpga-compile-nodes/m-p/1430568#M6592
It seems to me your problem is the same. Hope it helps.
Thank you very much for your help, I'll keep following the other post for more updates.
We apologize for the inconvenience caused. We are working on this internally, we will get back to you soon with an update.
Alekhya
Hi All,
Alekhya
Hi @filipeborralho ,
We could see that you've kudoed the above solution. Did our solution provided help? If this helps, please accept this as a solution. This might help others with similar issue. Thanks in advance!
Alekhya
Glad to know your issue is resolved. Thank you for accepting our solution. If you need further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
