Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1723 Discussions
ssh to devcloud fail on Intel network from China
pengfei
OS: ubuntu 18.04. The machine is connected to Intel network.
1. DevCloud user id is u48039 and dev server node is s099-n005
2. Proxy in china should be child-prc.intel.com:1080 (according to https://community.intel.com/t5/Intel-DevCloud/cannot-Connect-from-Linux-SSH/td-p/1143497)
3. The ~/.ssh/config file is as below
Host s099-n*
    User u48039
    IdentityFile ~/.ssh/colfax-access-key-48039
    ProxyCommand ssh -T devcloud-login "nc %h %p"
Host devcloud-login
    User u48039
    HostName localhost
    Port 4022
    ProxyCommand ssh -T devcloud-via-intel-proxy "nc s099 22"
Host devcloud-via-intel-proxy
    User guest
    HostName devcloud.intel.com
    LocalForward 4022 s099:22
    ProxyCommand nc -X 5 -x child-prc.intel.com %h %p
4.  After running ssh command, the ssh connection stuck in “debug1: Local version string……”.
(Normally, the following log should be “debug1: remote version…..”)
pengfei@pengfei-desk:~/.ssh$ ssh -vvv s099-n005
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n  7 Dec 2017
debug1: Reading configuration data /home/pengfei/.ssh/config
debug1: /home/pengfei/.ssh/config line 1: Applying options for s099-n*
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Executing proxy command: exec ssh -T devcloud-login "nc s099-n005 22"
debug1: permanently_drop_suid: 1000
debug1: key_load_public: No such file or directory
debug1: identity file /home/pengfei/.ssh/colfax-access-key-48039 type -1
debug1: identity file /home/pengfei/.ssh/colfax-access-key-48039-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
5. I can access devcloud with Jupyter notebook.
Any advice would be appreciated.
JananiC_Intel
Thanks for reaching out.
Kindly try the below config and let us know the updates.
Host devcloud
User u48039
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-48039.txt
ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
User guest
Hostname cluster.colfaxresearch.com
LocalForward 4022 c009:22
ProxyCommand nc -x child-prc.intel.com:1080 %h %p
pengfei
Thank you for your advice. Your suggestion pushed the connection process forward, but it still doesn't work.
This time, the ssh connection stuck at "debug2: we sent a publickey packet, wait for reply". You can see the detailed log below.
1. ~/.ssh/config
Host devcloud
User u48039
Port 4022
User guest
2. ssh log
pengfei@pengfei-desk:~/.ssh$ ssh -vvv devcloud
debug1: /home/pengfei/.ssh/config line 1: Applying options for devcloud
debug1: Executing proxy command: exec ssh -T devcloud-via-proxy
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3 pat OpenSSH* compat 0x04000000
debug2: fd 5 setting O_NONBLOCK
debug2: fd 4 setting O_NONBLOCK
debug1: Authenticating to devcloud:4022 as 'u48039'
debug3: put_host_port: [devcloud]:4022
debug3: hostkeys_foreach: reading file "/home/pengfei/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /home/pengfei/.ssh/known_hosts:4
debug3: load_hostkeys: loaded 1 keys from [devcloud]:4022
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:T1+mPVF6MMWeKddy10poM7Blr6atiOFxifGLF49BCUQ
debug1: Host '[devcloud]:4022' is known and matches the ECDSA host key.
debug1: Found key in /home/pengfei/.ssh/known_hosts:4
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug2: key: /home/pengfei/.ssh/colfax-access-key-48039 ((nil)), explicit
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey
debug3: start over, passed a different list publickey
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/pengfei/.ssh/colfax-access-key-48039
debug3: sign_and_send_pubkey: RSA SHA256:1SJi9O21UkR5zVc+8ORNGNTBn8rND+rhjabDc8/LAC4
JananiC_Intel
Thanks for the update.
Could try changing LocalForward 4022 s099:22 to LocalForward 4022 c099:22 in the config file ?
Try this and let us know the updates.
pengfei
I just tried. Still the same result.
JananiC_Intel
Sorry for the inconvenience,there is slight change in the previous comment.It is c009,not c099.Could you change LocalForward 4022 c099:22 to LocalForward 4022 c009:22 ?
If that doesn't work, try the below config
Host devcloud
User u48039
IdentityFile /home/mobaxterm/devcloud-access-key-48039.txt
ProxyCommand ssh -T devcloud-socks-proxy
Host devcloud-socks-proxy
User guest
IdentityFile "/home/mobaxterm/devcloud-access-key-48039.txt"
LocalForward 4036 colfaxserver:22
Change the IdentityFile path to your devcloud-access-key-48039.txt path.Try this and let us know.
pengfei
JananiC_Intel
The below config might clear your issue.Try this by replacing xxxxx with your id and let us know the updates.
Host devcloud
User uxxxxx
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-xxxxx.txt
User guest
#Hostname cluster.colfaxresearch.com
ProxyCommand nc -x proxy-shz.intel.com:1080 %h %p
#ProxyCommand nc -x proxy01.iind.intel.com:1080 %h %p
Host devcloud-direct
User uxxxxx
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-xxxxx.txt guest@devcloud.intel.com
pengfei
It doesn't work. The ssh connection process stucks in the same place. According to the advice, i changed my config file to :
Host devcloud
User u48039
Port 4022
User guest
User u48039
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-48039 guest@devcloud.intel.com
the log is as below:
debug2: reserved 0
debug2: reserved 0
JananiC_Intel
We have informed the admin team and your issue will be addressed as soon as possible.
JananiC_Intel
Sorry for the delayed response.
Intel TAC team will help you in this.Kindly contact Intel TAC team to fix the issue.
JananiC_Intel
We would discontinue monitoring this issue. Please raise a new thread incase of any further issues.
