OS: ubuntu 18.04. The machine is connected to Intel network.
1. DevCloud user id is u48039 and dev server node is s099-n005
2. Proxy in china should be child-prc.intel.com:1080 (according to https://community.intel.com/t5/Intel-DevCloud/cannot-Connect-from-Linux-SSH/td-p/1143497)
3. The ~/.ssh/config file is as below
Host s099-n*
User u48039
IdentityFile ~/.ssh/colfax-access-key-48039
ProxyCommand ssh -T devcloud-login "nc %h %p"
Host devcloud-login
User u48039
HostName localhost
Port 4022
ProxyCommand ssh -T devcloud-via-intel-proxy "nc s099 22"
Host devcloud-via-intel-proxy
User guest
HostName devcloud.intel.com
LocalForward 4022 s099:22
ProxyCommand nc -X 5 -x child-prc.intel.com %h %p
4. After running ssh command, the ssh connection stuck in “debug1: Local version string……”.
(Normally, the following log should be “debug1: remote version…..”)
pengfei@pengfei-desk:~/.ssh$ ssh -vvv s099-n005
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n 7 Dec 2017
debug1: Reading configuration data /home/pengfei/.ssh/config
debug1: /home/pengfei/.ssh/config line 1: Applying options for s099-n*
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Executing proxy command: exec ssh -T devcloud-login "nc s099-n005 22"
debug1: permanently_drop_suid: 1000
debug1: key_load_public: No such file or directory
debug1: identity file /home/pengfei/.ssh/colfax-access-key-48039 type -1
debug1: identity file /home/pengfei/.ssh/colfax-access-key-48039-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
5. I can access devcloud with Jupyter notebook.
Any advice would be appreciated.
Thanks for reaching out.
Kindly try the below config and let us know the updates.
Host devcloud
User u48039
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-48039.txt
ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
User guest
Hostname cluster.colfaxresearch.com
LocalForward 4022 c009:22
ProxyCommand nc -x child-prc.intel.com:1080 %h %p
Thank you for your advice. Your suggestion pushed the connection process forward, but it still doesn't work.
This time, the ssh connection stuck at "debug2: we sent a publickey packet, wait for reply". You can see the detailed log below.
1. ~/.ssh/config
Host devcloud
User u48039
Port 4022
User guest
2. ssh log
pengfei@pengfei-desk:~/.ssh$ ssh -vvv devcloud
debug1: /home/pengfei/.ssh/config line 1: Applying options for devcloud
debug1: Executing proxy command: exec ssh -T devcloud-via-proxy
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3 pat OpenSSH* compat 0x04000000
debug2: fd 5 setting O_NONBLOCK
debug2: fd 4 setting O_NONBLOCK
debug1: Authenticating to devcloud:4022 as 'u48039'
debug3: put_host_port: [devcloud]:4022
debug3: hostkeys_foreach: reading file "/home/pengfei/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /home/pengfei/.ssh/known_hosts:4
debug3: load_hostkeys: loaded 1 keys from [devcloud]:4022
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:T1+mPVF6MMWeKddy10poM7Blr6atiOFxifGLF49BCUQ
debug1: Host '[devcloud]:4022' is known and matches the ECDSA host key.
debug1: Found key in /home/pengfei/.ssh/known_hosts:4
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug2: key: /home/pengfei/.ssh/colfax-access-key-48039 ((nil)), explicit
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey
debug3: start over, passed a different list publickey
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/pengfei/.ssh/colfax-access-key-48039
debug3: sign_and_send_pubkey: RSA SHA256:1SJi9O21UkR5zVc+8ORNGNTBn8rND+rhjabDc8/LAC4
Thanks for the update.
Could try changing LocalForward 4022 s099:22 to LocalForward 4022 c099:22 in the config file ?
Try this and let us know the updates.
Sorry for the inconvenience,there is slight change in the previous comment.It is c009,not c099.Could you change LocalForward 4022 c099:22 to LocalForward 4022 c009:22 ?
If that doesn't work, try the below config
Host devcloud
User u48039
IdentityFile /home/mobaxterm/devcloud-access-key-48039.txt
ProxyCommand ssh -T devcloud-socks-proxy
Host devcloud-socks-proxy
User guest
IdentityFile "/home/mobaxterm/devcloud-access-key-48039.txt"
LocalForward 4036 colfaxserver:22
Change the IdentityFile path to your devcloud-access-key-48039.txt path.Try this and let us know.
The below config might clear your issue.Try this by replacing xxxxx with your id and let us know the updates.
Host devcloud
User uxxxxx
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-xxxxx.txt
User guest
#Hostname cluster.colfaxresearch.com
ProxyCommand nc -x proxy-shz.intel.com:1080 %h %p
#ProxyCommand nc -x proxy01.iind.intel.com:1080 %h %p
Host devcloud-direct
User uxxxxx
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-xxxxx.txt guest@devcloud.intel.com
It doesn't work. The ssh connection process stucks in the same place. According to the advice, i changed my config file to :
Host devcloud
User u48039
Port 4022
User guest
User u48039
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-48039 guest@devcloud.intel.com
the log is as below:
debug2: reserved 0
debug2: reserved 0
We have informed the admin team and your issue will be addressed as soon as possible.
Sorry for the delayed response.
Intel TAC team will help you in this.Kindly contact Intel TAC team to fix the issue.
We would discontinue monitoring this issue. Please raise a new thread incase of any further issues.
