Emulating AVX on older CPU in order to use OpenVINO
Gouveia__César
I have made a previous post on if I could run OpenVINO on a CPU which does not support AVX (post) and the answer was:
If you're installing OpenVINO on a CPU that does not support AVX instructions, the installation will fail. As per the system requirements, a 6th to 10th generation Intel Core, Intel Xeon processor, Pentium® processor N4200/5, N3350/5, N3450/5 with Intel® HD Graphics is required. There aren't any workarounds to this that are verified by Intel.
However, what if I try to use an AVX emulator like this one provided by Intel?
https://software.intel.com/en-us/articles/pre-release-license-agreement-for-intel-software-development-emulator-accept-end-user-license-agreement-and-download
It will work? This kind of AVX emulator has ever been tested with OpenVINO?
César.
Sahira_Intel
Hi César,
Tensorflow provides prebuilt binaries with AVX instructions enabled (so when installing OpenVINO on a system that does not support AVX instructions, Tensorflow is the limiting factor). Using an AVX emulator has not been tested with OpenVINO, but you might be able to do it.
Alternatively, you can convert your model to IR on a system that supports AVX instructions, the run inference on one that does not. You can also try compiling Tensorflow binaries from source if you cannot use a CPU that supports AVX.
I hope this information is helpful.
Sincerely,
Sahira
Gouveia__César
Hi Sahira,
I'm using MXNet instead of Tensorflow so I don't know if this applies to me. Moreover, I know that you can install a tensorflow version that does not use AVX.
How is this possible if the HAVE_AVX flag is defined at compile time???
César.
Gouveia__César
Hi Sahira,
Can you please take a look at my answer?
Thanks in advance,
César.
