6605 Discussions
Entry not found - Problem with verification scripts
nirwan
I'm new in OpenVino. I installed OpenVino and run verification scripts.
I have Windows 10.
I've installed :
- Microsoft Visual Studio 2019
- CMake 3.14
- Python 3.6
- OpenVino Toolkit 2019 R2, later R1.1
I've set the environment variables (run setupvars.bat), configure the model optimizer for all configuration (run install_prerequisites.bat/ or run single script for every model)
I start using verification scripts : demo_squeezenet_download_convert_run.bat or demo_security_barrier_camera.bat.
Finally, I got message box with info:
classification_sample.exe - Entry Point not found.
The procedure entry point
?internal_max_conccurency@task_arena_base@internal@interface7@tbb@KAHEBVtask_arena@34@@Z could not be located in the dynamic library C:\Program Files (x86)\InterSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\interference_engine.dll
?internal_max_conccurency@task_arena_base@internal@interface7@tbb@KAHEBVtask_arena@34@@Z could not be located in the dynamic library C:\Program Files (x86)\InterSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\cpu_extension.dll
What's wrong ?
Magda
nirwan
 tbb.dll  file was a problem. It is in Windows directory (I use a software which it requires).  Answer:
https://www.mathworks.com/matlabcentral/answers/115024-errors-in-making-standalone-program-using-matlab-2013b
M.
Shubha_R_Intel
Dear nirwan
 Thanks for sharing your findings with the OpenVino community ! Something you can always do to resolve problems such as these though is use http://www.dependencywalker.com/ . It's an indispensable tool when doing Windows programming.
Shubha
