6574 讨论
OpenVINO toolkit for Ubuntu 22.04 on Raspberry Pi 4
nilutpol_kashyap
初学者
2,538 次查看
I am working on a project using ROS 2 Humble on Raspberry Pi 4 with Ubuntu 22.04 OS.
Is it possible to install Openvino toolkit on Ubuntu 22.04 on Raspberry Pi 4? I plan to use the Intel NCS 2 for inferencing and combine with ROS 2.
0 项奖励
7 回复数
Peh_Intel
主持人
2,505 次查看
Hi nilutpol_k,
For your information, OpenVINO™ Toolkit for the Raspbian OS Package is only validated for Raspbian Buster,32 bit and Raspbian Stretch, 32-bit.
For Raspberry Pi with Ubuntu OS, you have to build OpenVINO™ from open source (see build instructions). However, building OpenVINO™ from open source is only validated on Ubuntu 18.04 and 20.04.
To answer your question, it should be possible to build OpenVINO™ from open source on Ubuntu 22.04 on RPI with a caveat.
Peh
0 项奖励
nilutpol_kashyap
初学者
2,499 次查看
Hi Peh,
Thank you for your reply.
So can i build OpenVINO from source onto Ubuntu 20.04 on a Raspberry Pi 4?
Also is it feasible to build OpenVINO  from source on Ubuntu 22.04 on Raspberry Pi 4 as OpenVINO is still not available for Ubuntu 22.04?
Nilutpol
0 项奖励
Peh_Intel
主持人
2,472 次查看
Hi Nilutpol,
Yes, you can build OpenVINO from source onto Ubuntu 20.04 on a Raspberry Pi 4.
Building OpenVINO from source onto Ubuntu 22.04 on a Raspberry Pi 4 is not yet validated by development team and tested on our side. However, I am seeing other folks successfully built OpenVINO from source onto Ubuntu 22.04 but not sure whether the compiling is on Raspberry Pi.
Peh
0 项奖励
nilutpol_kashyap
初学者
2,465 次查看
Hi Peh,
I will try installing OpenVINO from source on Ubuntu 20.04 by following the instructions. I will as questions here if I face any issues.
Thank you
Nilutpol
0 项奖励
TrinhHuy
初学者
2,456 次查看
Can I build OpenVINO from source on Ubuntu 20.04 Raspberry Pi 3b as I cannot see in supported device list
0 项奖励
Peh_Intel
主持人
2,422 次查看
Hi TrinhHuy,
Raspberry Pi 3B should work as well for NCS2.
Peh
0 项奖励
Peh_Intel
主持人
2,351 次查看
Hi Nilutpol,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
0 项奖励
回复
