Openvino Custom YOLO Inference Issue
SANTHAKUMAR91
初學者
5,846 檢視
I have trained a custom darknet yolo for character recognition and successfully converted darket net model -> keras -> tensorflow -> IR <Openvino format>. I was able to do inference in openvino Yolov3 Async inference code with few custom changes on parsing yolo output. The results are same as original model. But when tried to replicated the same in c++, the results are wrong. I did small work around on the parsing output results.  I managed to get the results but they are not the same as Openvino python inference.
Issues:
1. Predictions are deviated by little offset.
2. Certain bbox predictions are missing.
This issues are not seen in Python inference.
The Yolo Network Details:
num = 2
coords = 4
classes = 35
anchors=  { 3.638, 5.409, 3.281, 4.764 }
Input 1 x 3 x 80 x 240 - NCHW
output = 10 x 30 x 80 - Blob Output
Kindly help me resolving the issue. Thanks
0 積分
1 解決方案
IntelSupport
管理員
5,736 檢視
Hi Santhakumar,
Thanks for your patience. We have tested your inference code, however, we are unable to replicate the same result as yours on the C++ inference code. You might need to change your customer code. Meanwhile, I noticed that your yolodetector.cpp is similar to our main.cpp file in Multi-Channel Object Detection Yolov3 C++ Demo. I would advise you to use it as a reference for your customer inference code as it has been tested and validated for yolo-v3 model. Also, on why both platforms give different results while running the same model- it may due to some library and component availabilities on Phyton are well covered compared to C++.
Aznie
在原始文章中檢視解決方案
14 回應
IntelSupport
管理員
5,802 檢視
Hello Santhakumar91,
Thanks for reaching out. We are investigating this issue and will update you with the information soon. Meanwhile, could you share your model and inference code for us to test it on our end?
Aznie
SANTHAKUMAR91
初學者
5,789 檢視
Thanks for the response. I have attached the model and code.
I have used Openvino 2021.3.0 version.
IntelSupport
管理員
5,760 檢視
Could you please share the source of the OCR model that you used. Thanks.
Aznie
SANTHAKUMAR91
初學者
5,750 檢視
Its a customized yolo v3 using the darknet source. Trained on custom dataset.
IntelSupport
管理員
5,737 檢視
Hi Santhakumar,
Aznie
IntelSupport
管理員
5,685 檢視
Hi Santhakumar,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
Aznie_Intel
主席
5,646 檢視
Hi Santhakumar,
The developer team is looking into your Yolov3 Async C++ inference performance issues. I will update you once we obtain feedback from them.
Aznie
IntelSupport
管理員
5,614 檢視
Hi Santhakumar,
Did you train the model with yolo3? We found that the C++ code is based on yolo5 and the python code s based on yolo3.
Aznie
SANTHAKUMAR91
初學者
5,597 檢視
Hi Aznie,
Yes the model is trained on yolo v3 architecture.
IntelSupport
管理員
5,593 檢視
Hi Santhakumar,
Could you provide us the compilation step for C++ compilation or CMAKE package so that we can directly compile?
Aznie
IntelSupport
管理員
5,541 檢視
Hi Santhakumar,
Is it possible for you to share with us your Makefile or compilation step? We need it to determine the issue that happens with your C++ custom code.
Aznie
SANTHAKUMAR91
初學者
5,528 檢視
Hi , This is Visual Studio Project, i have used "security_barrier_camera_demo"  project from openvino for setup and execution. Thanks
IntelSupport
管理員
5,514 檢視
Hi Santhakumar,
Thank you for your reply. Do you still need any help regarding this?
Aznie
IntelSupport
管理員
5,419 檢視
Hi Santhakumar,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
回覆
