6577 Discussions
Running Stable diffusion XL with optimum[openvino] is using half the total logical cores
Rajiv_Mandal
I am running the below code for using the stabilityai/stable-diffusion-xl-base-1.0 from HuggingFace, optimizing it with Optimum Intel for Openvino. When running the inference, I am doing htop utility. I am seeing that is is using only half of the logical cores present in the Xeon server. I am using the m7i.8xlarge EC2 instance in AWS, which has 16 physical cores, 32 logical cores on a one socket Sapphire Rapids Xeon Server. I am using Ubuntu24.04
While launching the jupyter notebook, I have used the command below to launch jupyter notebook using all 32 logical cores.
taskset -c 0-31 jupyter-lab --ip 0.0.0.0 --no-browser --allow-root
This is the code I am running in the jupyter notebook:
!pip install --upgrade-strategy eager optimum["openvino"]
!pip install diffusers
!pip install huggingface_hub
from huggingface_hub import notebook_login
notebook_login()
from optimum.intel import OVStableDiffusionXLPipeline
model_id = "stabilityai/stable-diffusion-xl-base-1.0"
pipeline = OVStableDiffusionXLPipeline.from_pretrained(model_id, export=True)
# Don't forget to save the exported model
pipeline.save_pretrained("openvino-sd-xl-base-1.0")
# Here is the inference code for using the Openvino converted model and running an inference for converting text to image using the converted model.
import os
from openvino.runtime import Core
#Use Environment Variables: Set the environment variables directly in your script to ensure they are applied:
os.environ["OMP_NUM_THREADS"] = "32"
os.environ["MKL_NUM_THREADS"] = "32"
os.environ["OPENBLAS_NUM_THREADS"] = "32"
os.environ["NUMEXPR_NUM_THREADS"] = "32"
# Initialize OpenVINO's Core object
core = Core()
# Set the number of threads to the total number of logical processors (vCPUs)
core.set_property("CPU", {
"INFERENCE_NUM_THREADS": "32",
"NUM_STREAMS": "1",
"CPU_BIND_THREAD": "YES" # Bind threads to specific cores
# Load the OpenVINO IR format model using the custom Core object
pipeline = OVStableDiffusionXLPipeline.from_pretrained("openvino-sd-xl-base-1.0", ov_core=core)
# Run inference for text-to-image generation
prompt = "boat in an ocean"
image = pipeline(prompt, num_inference_steps=50).images[0]
# Display the generated image
from IPython.display import display
display(image)
Aznie_Intel
Hi Rajiv Mandal,
Thanks for reaching out.
Can you enable the CPU cores by Multi-Threading Optimization? Use the properties below to limit the availability of CPU resources for model inference. The OpenVINO Runtime will perform multi-threading scheduling based on the limited available CPU if the platform or operating system supports this behavior.
  • ov::inference_num_threads
  • ov::hint::scheduling_core_type
  • ov::hint::enable_hyper_threading
Please take a look at Multi Threading Optimization for more information.
Aznie
Aznie_Intel
Hi Rajiv Mandal,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
