I want to use Telegraf.
Telegraf and Datastore is running.
but I don't know how to set config files.
Hi Siyoung,
Could you run docker ps and verify that the Multimodal Data Visualization microservice is up, you can access Grafana at http://<HOST_IP>:3000. For the user name and password, take a look at the edge_insights_industrial/Edge_Insights_for_Industrial_4.0.0/IEdgeInsights/Visualizer/multimodal-data-visualization/eii/grafana.ini in the security section. This will help you visualize the data.
Jesus
Hi Siyoung,
There is a default telegraf configuration that is loaded, take a look at the [WORK_DIR]/IEdgeInsights/Telegraf/config/Telegraf/Telegraf.conf file. Additional information ca be found in the documentation: Telegraf Overview — EII Documentation v1.0 documentation (intel.com)
There is also an example on how to configure Telegraf and the message bus. Hope this help!
Jesus
Then I want to see visualized data of influxdb, so I changed ifluxdb version 1.8.7 to 2.0.0.
but still I can't see the visualized data in 8086 port.
config of Datastore and influxdb
Hi Siyoung,
Jesus
![](/skins/images/76AB59DE81B739925661148447ECFE36/responsive_peak/images/icon_anonymous_message.png)
