Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Can't open Questa Intel FPGA
ofekgolan
Hi All,
I have downloaded Quratus 21.1 lite edition with Questa Intel FPGA simulator to my Win11 PC. I have hard time to open Questa, not sure if that license or not, I have setup .dat file as fixed license.
I attach the error whilr ttying to reload RTL simulation via Quartus after compilation.
And environment variables declared.
In addition, the nativelink_simulation.rpt :
Info: Start Nativelink Simulation process
executing command line: ip-make-simscript --nativelink-mode --output-directory=push_pop_iputf_input --spd=E:/Documents/projects/fpga/push_pop/pll.spd
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cyclonev
Quartus root : d:/programs/intelfpga_lite/21.1/quartus/bin64/
Quartus sim root : d:/programs/intelfpga_lite/21.1/quartus/eda/sim_lib
Simulation Tool : questa intel fpga
Simulation Language : systemverilog
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation\modelsim
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script d:/programs/intelfpga_lite/21.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Error: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: issued_nl_message
Nativelink TCL script failed with errorInfo: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
while executing
"error "$emsg" "" "issued_nl_message""
invoked from within
"if [ catch {exec $vsim_cmd -version} version_str] {
set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..."
(procedure "launch_sim" line 88)
invoked from within
"launch_sim launch_args_hash"
("eval" body line 1)
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if [ info exists ::errorCode ] {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $..."
invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
set status 1
set save..."
(procedure "run_sim" line 74)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
error "$result" $savedInfo ..."
(procedure "run_eda_simulation_tool" line 334)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
AR_A_Intel
Hi Sir
Welcome to INTEL forum. To further understand the issue, could you get me the:
1) Screenshot of environment variables setup
2) Machine OS information
3) Quartus version used
4) lmutil lmdiag
5) License.dat file (Questa)
6) Screenshot of Quartus >> tools >> license setup
7) computer NICID
And for privacy, you can reply/attach your file in private message
ofekgolan
I solved the issue by downloading msvc dll file.
AR_A_Intel
Thanks for your update information. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
