hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1292 Discussões
I am almost certain that my Quartus II web 13.1 program creates RTL schematics with errors in them. (I have not upgraded the installation afterwards because my computer is offline!).
AVanB3
Principiante
9.179 Visualizações
Please see next screencopy that shows the wrong 2'h1 and 2'h2 markings (they should be exchange) in the Mux4to1 example. Also the RTL schematic of the 4to2 Mux makes no sense to me. Can you please explain me if I'm correct and if not how to intepret the
38 Respostas
AVanB3
Principiante
3.532 Visualizações
Sadly even saving the QAR file of the BRAM16x2 example failed to complete successfully. Therefore I also included the errorlog files into a combined rar file. Hereby added. And I will try to open the Quartus II simulation question into the correct Forum links later on.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
The rar file is corrupted. Could you reattach?
KhaiY
AVanB3
Principiante
3.532 Visualizações
Hi KhaiY, I tried to login on the Intel page to answer but the URL somehow was rejected. See attached screencopy. Therefore I answer you by using my mail for replying. (I used my Opera browser when that error page generated). I tested my supposed 'corrupted' attachment file and was completely able to open and extract all single files. So I think it is the by the Quartus II program generated files that make them unusable? Because as said I got an error warning that said the program couldn't completely generate the files because the BRAM16x1S/16x2 VHDL file wasn't entirely successfully compiled. (Note that Xilinx ISE 14.6 had no problem with this same VHDL file!). I can resend you the files again but I think that it will make no difference when Quartus fails to completely compile again? Thanks. Albert.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
Can you send the entire project directory in ZIP?
KhaiY
AVanB3
Principiante
3.532 Visualizações
Hereby I hope to attach the right information you asked KhaiY. I attach 2 packed files. The file output files is from that Altera 13.1 map.
Hope they shed a light on solving this BRAM 16x2 question.
Albert.
AVanB3
Principiante
3.532 Visualizações
I notice it only attached the one file upload so I try to upload the Output files file again.
Thanks!
Albert.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
In the .map.rpt file you have attached, there are two error messages:
Error (12006): Node instance "U0" instantiates undefined entity "BRAM_16x1S" File: J:/altera/13.1/bram_16x2.vhd Line: 46
Error (12006): Node instance "U1" instantiates undefined entity "BRAM_16x1S" File: J:/altera/13.1/bram_16x2.vhd Line: 49
The error indicates that the BRAM_16x1S HDL file is not added to the Project. I compile the qar file, there is no BRAM_16x1S file in the project directory. Can you check if you have add this file to the project? You may check from the Project Navigator.
KhaiY
AVanB3
Principiante
3.532 Visualizações
Hi KhaiY, the vhdl file contains a component named BRAM_16x1S as part of the archive BRAM16x2 archtecture. It works splendidly as it is in Xilinx ISE 14.6. But Quartus 13.x fails to compile this same vhdl file. This is that file:
-- Company:
-- Engineer:
-- Create Date:  22:57:22 05/09/2020
-- Design Name:
-- Module Name:  BRAM_16x2 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
--BRAM_16x2 blz.194
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity BRAM_16x2 is
   port (q_out : out std_logic_vector (1 downto 0);
write_en : in std_logic;
clk: in std_logic;
d_in: in std_logic_vector (1 downto 0);
a_in: in std_logic_vector (3 downto 0));
end BRAM_16x2;
architecture BRAM_arch of BRAM_16x2 is
component BRAM_16x1S is
port(O : out std_logic;
D: in std_logic;
A3, A2, A1, A0: in std_logic;
WE, W_CLK: in std_logic);
end component;
begin
U0: BRAM_16x1S port map (O =>q_out(0), WE =>write_en, W_CLK =>clk, D =>d_in(0),
A0 =>a_in(0), A1 =>a_in(1), A2 =>a_in(2), A3 =>a_in(3));
U1: BRAM_16x1S port map (O =>q_out(1), WE => write_en, W_CLK => clk, D =>d_in(1),
end BRAM_arch;
I'll add it hereby as attachement too.
Thanks again for taking the time to look into the problem!
Albert.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
The BRAM_16x2vhd is instantiating the BRAM_16x1S but there is no BRAM_16x1S HDL file in the archive.
Could you provide BRAM_16x1S ?
KhaiY
AVanB3
Principiante
3.532 Visualizações
Hi KhaiY, that is the problem, why it probably isn't working in Quartus II. But this file as it is, works splendidly in Xilinx ISE 14.6 without any problem! That is why I asked this question. I just noticed that it only works in Xilinx ISE 14.6 when a higher type FPGA is chosen. Earlier Xilinx FPGA's probably were unable to work as BRAM configurated FPGA's.
Because a Xilinx Spartan 3E failed to compile this BRAM file that works splendidly on a Xilinx Zynq XA 7z010 FPGA as it was given in the above mentioned BRAM_16x2 vhdl file from the book : PLD BASED DESIGN WITH VHDL by Vaibbhav Taraate.
I know too little yet about the Quartus II and Xilinx ISE programs to know why the file creates problems in Quartus II. But I guess it has to do with what version of program is used.
Thanks!
Albert.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
I appreciate your explanation on the issue, but unfortunately we are not in liberty to discuss on our FPGA software especially in comparison to our competitor products.
I am happy to address the implementation challenges that is related to our FPGA software. In general, all the source files need to be added to the project directory for successful compilation. In this case, the software reports that the source file for BRAM_16x1S is missing in the project directory. You have to add the source file for this BRAM_16x1S if you want to instantiate it in the bram_16x2.vhd file.
KhaiY
AVanB3
Principiante
3.532 Visualizações
Understood KhaiY. But since the current file worked in Xilinx without the BRAM_16x1S file, it wasn't needed and therefore not given in the mentioned book. And if I had that file I wouldn't know how to add it to the project anyhow. Especially if it can't be added to the existing vhdl file. I already tried to do that previously to get it compiled in Quartus until I found out that it already worked in its present version in Xilinx ISE 14.6.
Best regards.
Albert.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
In the Intel Quartus Prime software, you have to add the logic design files that contain the logic that implements your design into the Project. The source file can be in HDL(.v/.vhd/.sv), Verilog Quartus Mapping (.vqm) design files and Platform Designer (Standard) system (.qsys). It this case, it is not possible to instantiate BRAM_16x1S without the source file that describes how BRAM_16x1S works in the design.
To add the files into the Project
1) Click on Project > Add/Remove Files in Project
2) Click on ... icon  to add the files
3) Ok
KhaiY
AVanB3
Principiante
3.532 Visualizações
Thanks KhaiY, I will try your much appreciated explanation later on today when I'm back from my job. I hope that I will manage to get the BRAM file running in Quartus this time.
Have a great day!
Albert.
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
Sure. Do let me know if you have any questions.
KhaiY
KhaiChein_Y_Intel
Funcionário
3.532 Visualizações
Hi Albert,
Do you have any other questions? If no, I shall transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
KhaiY
AVanB3
Principiante
3.532 Visualizações
Hi KhaiY, I haven't any other questions at the moment and haven't tried yet to write the BRAM simulator vhdl code you suggested me to add to the in Quartus II failing compilation. I am just starting to write my first simulation code if I find time and when I exactly know how to do that. Been busy with other things in electronics I know more about. Also still waiting on another book on VHDL. But Covid-19 has put shipment at a halt for the last 3 months and it seems that it isn't coming soon either from Bookvistas in India and ordered through Amazon.de. Thanks KhaiY, Best regards and thanks for you trying me to understand how some things in Quartus work. But without online connection the Quartus Help database is sadly greatly missed and should be integrated in the program for offline access. Have a great week! Albert.
KhaiChein_Y_Intel
Funcionário
3.531 Visualizações
Hi Albert,
Sure. You are welcome to open a new forum thread if you need help in the future.
KhaiY
Responder
