Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Max7000A CPLD programming, MAX PLUS II
base2che
Hi there,
we have several dozen legacy hardware platforms that we need to program with the Max7000A cpld (EPM7265A). Research indicates that this is only supported with the MAX PLUS II software (does not work with Quartus).
Is there any way to obtain MAX PLUS II?
Thanks anyone for your help on this, it is fairly urgent for us to get this platform running, as a respin for this board is out of the question for our deadline.
Thanks and cheers!
Chester
ak6dn
Valued Contributor III
Exactly what part number(s)?
Do you need to just (re)program devices with an existing image?
Or start with updated source code and regenerate new programming images?
base2che
It is EPM7256ATC100-7.
We need to use updated source code and generate new images.
/Chester
NurAiman_M_Intel
ak6dn
Unfortunately 13.0sp1/13.1 do not support the MAX EPM7000A series.
The requested MaxPlusII 10.2 version is required for that series of that family.
NurAiman_M_Intel
You can refer to ADV 2030 for discontinuance of MAX+PLUS II.
https://www.intel.com/content/www/us/en/content-details/677733/customer-advisory-adv2030-discontinuance-of-max-plus-ii-software.html?DocID=677733
In the ADV2030, it mention that you can option for Quartus 13.0 SPI for MAX7000.
Since the device MAX7000 and MAX+PLUS II software is obsolete, we only have limited information on this. Hence we are unable to support this case further.
Aiman
ak6dn
As an FYI, regardless of what ADV 2030 says, I have Quartus 13.0sp1 installed with MAX7000 support, and use it all the time for 3000A and 7000S devices. The ONLY supported/available MAX series devices listed under the Device Selection Menu are:
  • MAX3000A
  • MAX7000AE
  • MAX7000B
  • MAX7000S
Specifically the following are NOT available for selection. Any members of:
  • MAX3000
  • MAX7000
  • MAX7000A
So I would postulate Quartus 13.0sp1 is not an option and probably MaxPlusII 10.2 is the only viable solution.
ADV 2030 is INCORRECT in stating that MAX7000 and/or MAX7000A are supported by Quartus 13.0sp1.
