Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
pong game
i tried to run pong game in fpga prototyping with vhdl examples book chapter 13 but i couldn't run that can you help me
not without knowing whats wrong.
i used codes in the book i want to write in the vga pau logo but i couldn't that
Please post the code you're trying to get working, and tell us the errors.
these are codes
library ieee;
use ieee. std_logic_1164. all ;
use ieee. numeric_std. all ;
entity pong_graph_animate is
port (
clk, reset : std_logic ;
btn: std_logic_vector (1 downto 0 ) ;
video_on: in std_logic;
pixel_x , pixel_y : in std_logic_vector ( 9 downto 0) ;
graph_rgb : out std_logic_vector (2 downto 0);
hit:out std_logic;
gra_still: in std_logic;
miss: in std_logic;
graph_on : in std_logic
end pong_graph_animate ;
architecture arch of pong_graph_animate is
signal refr_tick : std_logic;
--x , y c o o r d i n a t e s (0,0) to ( 639 , 479 )
signal pix_x,pix_y : unsigned ( 9 downto 0) ;
constant MAX_X: integer :=640;
constant MAX_Y: integer:=480;
-- w a l l l e f t , r i g h t b o u n d a r y
constant WALL_X_L : integer :=32 ;
constant WALL_X_R: integer :=35;
-- b a r l e f t , r i g h t b o u n d a r y
constant BAR_X_L: integer :=600;
constant BAR_X_R: integer :=603;
--b a r t o p , b o t t o m b o u n d a r y
signal bar_y_t , bar_y_b : unsigned ( 9 downto 0) ;
constant BAR_Y_SIZE: integer :=72;
-- reg t o t r a c k t o p b o u n d a r y ( x p o s i t i o n is f i x e d )
signal bar_y_reg , bar_y_next : unsigned ( 9 downto 0) ;
-- b a r moving v e l o c i t y when a b u t t o n i s p r e s s e d
constant BAR_V: integer:=4;
-- s q u a r e b a l l
constant BALL_SIZE: integer:=8; -- 8
-- b a l l l e f t , r i g h t b o u n d a r y
signal ball_x_l, ball_x_r : unsigned ( 9 downto 0) ;
-- b a l l t o p , b o t t o m b o u n d a r y
signal ball_y_t , ball_y_b : unsigned (9 downto 0) ;
-- reg t o t r a c k l e f t , t o p b o u n d a r y
signal ball_x_reg , ball_x_next ,ball_vx_reg : unsigned ( 9 downto 0) ;
signal ball_y_reg , ball_y_next ,ball_vy_reg : unsigned ( 9 downto 0) ;
--reg t o t r a c k b a l l s p e e d
signal x_delta_reg , x_delta_next : unsigned ( 9 downto 0 ) ;
signal y_delta_reg , y_delta_next : unsigned ( 9 downto 0 ) ;
-- b a l l v e l o c i t y c a n be p o s o r neg
constant BALL_V_P : unsigned ( 9 downto 0 )
:= to_unsigned ( 2,10) ;
constant BALL_V_N: unsigned ( 9 downto 0)
:= unsigned ( to_signed (-2,10));
-- r o u n d b a l l i m a g e ROM
type rom_type is array (0 to 7 )
of std_logic_vector ( 0 to 7 ) ;
-- ROM d e f i n i t i o n
constant BALL_ROM: rom_type :=
"00111100" , -- * * * *
"01111110", -- * * * * * *
"11111111", -- * * * * * * * *
"00111100" --* * * *
signal rom_addr , rom_col : unsigned ( 2 downto 0 ) ;
signal rom_data : std_logic_vector ( 7 downto 0) ;
signal rom_bit : std_logic ;
-- o b j e c t o u t p u t s i g n a l s
signal wall_on ,bar_on , sq_ball_on , rd_ball_on : std_logic ;
signal wall_rgb,bar_rgb , ball_rgb :
std_logic_vector ( 2 downto 0) ;
begin
-- r e g i s t e r s
process ( clk , reset)
begin
if reset = '1' then
bar_y_reg <= ( others => '0' ) ;
ball_x_reg <= ( others => '0' ) ;
ball_y_reg <= ( others => '0' ) ;
x_delta_reg <= ( "0000000100" ) ;
y_delta_reg <= ( "0000000100") ;
elsif( clk'event and clk = '1' ) then
bar_y_reg <= bar_y_next ;
ball_x_reg <= ball_x_next ;
ball_y_reg <= ball_y_next ;
x_delta_reg <= x_delta_next ;
y_delta_reg <= y_delta_next ;
end if ;
end process;
pix_x <= unsigned ( pixel_x ) ;
pix_y <= unsigned ( pixel_y ) ;
refr_tick <= '1' when ( pix_y = 481 ) and (pix_x=0) else
'0';
wall_on <='1' when (WALL_X_L <= pix_x ) and (pix_x<=WALL_X_R) else
'0';
wall_rgb <= "001"; -- b l u e
-- b o u n d a r y
bar_y_t <= bar_y_reg ;
bar_y_b <= bar_y_t + BAR_Y_SIZE - 1;
-- p i x e l w i t h i n b a r
bar_on <=
'1' when (BAR_X_L<=pix_x) and (pix_x<=BAR_X_R) and
(bar_y_t <= pix_y ) and ( pix_y <= bar_y_b ) else
'0' ;
-- b a r r g b o u t p u t
bar_rgb <= "001" ; --green
-- new b a r y - p o s i t i o n
process ( bar_y_reg , bar_y_b , bar_y_t , refr_tick , btn)
begin
bar_y_next <= bar_y_reg ; -- no move
if refr_tick = '1' then
if btn (1) = '1' and bar_y_b<(MAX_Y-1-BAR_V) then
bar_y_next <= bar_y_reg + BAR_V; -- move down
elsif btn ( 0 ) = '1'and bar_y_t > BAR_V then
bar_y_next <= bar_y_reg - BAR_V ; -- move up
end if;
end if;
end process;
-- b o u n d a r y
ball_x_l <= ball_x_reg ;
ball_y_t <= ball_y_reg ;
ball_x_r <= ball_x_l + BALL_SIZE - 1;
ball_y_b <= ball_y_t + BALL_SIZE - 1;
-- p i x e l w i t h i n b a l l
sq_ball_on <=
'1' when ( ball_x_l <= pix_x ) and ( pix_x <= ball_x_r ) and
( ball_y_t <= pix_y ) and ( pix_y <= ball_y_b ) else
'0' ;
-- map c u r r e n t p i x e l l o c a t i o n t o ROM a d d r / c o l
rom_addr <= pix_y(2 downto 0) - ball_y_t(2 downto 0 ) ;
rom_col <= pix_x(2 downto 0 ) - ball_x_l(2 downto 0 ) ;
rom_data <= BALL_ROM(to_integer(rom_addr));
rom_bit <= rom_data(to_integer(rom_col));
rd_ball_on<='1'when (sq_ball_on='1') and (rom_bit='1') else
'0' ;
ball_rgb <= "100" ; -- red
ball_x_next <=
to_unsigned((MAX_X)/2,10) when gra_still='1' else
ball_x_reg + ball_vx_reg when refr_tick='1' else
ball_x_reg ;
ball_y_next <=
to_unsigned((MAX_Y)/2,10) when gra_still='1' else
ball_y_reg + ball_vy_reg when refr_tick='1' else
ball_y_reg ;
process ( ball_vx_reg , ball_vy_reg , ball_y_t,ball_x_l, ball_x_r ,
ball_y_t,ball_y_b,bar_y_t,bar_y_b,gra_still,hit,miss)
begin
hit <= '0' ;
miss <= '0' ;
ball_vx_next <= ball_vx_reg;
ball_vy_next <= ball_vy_reg;
if gra_still= '1' then -- i n i t i a 1 v e 1 o c i t y
ball_vx_next <= BALL_V_N;
ball_vy_next <= BALL_V_P;
elsif ball_y_t < 1 then
elsif ball_y_b > (MAX_Y-1) then -- r e a c h b o t t o m
ball_vy_next <= BALL_V_N;
elsif ball_x_1 <= WALL_X_R then -- r e a c h w a l l
ball_vx_next <= BALL_V_P; -- b o u n c e b a c k
elsif (BAR-X-L <=ball-x-r) and (ball-x-r <=BAR-X-R) and
(bar_y_t<=ball_y_b) and (ball_y_t<=bar_y_b) then
-- r e a c h x of r i g h t b a r , a h i t
ball_vx_next <= BALL_V_N; -- b o u n c e b a c k
hit <= '1';
elsif (ball_x_r>MAX_X) then --r e a c h r i g h t b o r d e r
miss <= '1' ; -- a mi s s
end if ;
end process ;
graph_on <= wall_on or bar_on or rd_ball_on;
process(video_on,wall_on,bar_on,rd_ball_on,
wall_rgb, bar_rgb, ball_rgb)
begin
if video_on='0' then
graph_rgb <= "000" ; --blank
else
if wall_on = '1' then
graph_rgb <= wall_rgb;
elsif bar_on = '1' then
graph_rgb<= bar_rgb ;
elsif rd_ball_on = '1' then
graph_rgb <= ball_rgb;
else
graph_rgb <= "110"; -- y e l l o w background
end if ;
end if ;
end process ;
end arch;
errors
can't write to interface object ''miss'' of mode IN
interface object ''hit''of mode out cannot be read.change object mode to buffer
i added the hit:out std_logic, gra_still: in std_logic, miss: in std_logic, graph_on : in std_logic
error can be from this
I think your error is self explanitory.
You cannot write to an input port. You need to make it an output.
Also, outputs cannot be read internally. Either make it a buffer (like it suggests) or use an internal signal.
--- Quote Start ---
--- Quote End ---
" I have tried to run the above code but and they are executing successfully , the problem that is not that how do I assign the pins, auto assigning the pin gives a wrong output and when using the DE1 pin assignment how do i change the name as there is discrepancy in naming system "
https://www.alteraforum.com/forum/attachment.php?attachmentid=6640
