FORTRAN 77 F2C
heysiattalab__saeed
Hello all. I have some FORTRAN 77 code that I am trying to convert it to C/C++ using F2C. I can compile my FORTRAN source code using IVF but when I am trying to convert it to C using F2C I get the following error :
Error on line 5 of TAGLINE.INS: unclassifiable statement (starts "structure/")
Error on line 33 of TAGLINE.INS: unclassifiable statement (starts "record/sta")
TAGLINE.INS is NOT my source file. It is an include file that I include it in my source code and F2C complains about include file. Here is my include file (TAGLINE.INS) :
C
C
C***  SCRATCH INPUT DATA FROM FILE FNAM  (.RTV = RAW INPUT TAG VALUE)
C
          STRUCTURE  /STAGRICL/
            CHARACTER*76     UFN     !! U72 FILENAME.UP.CASE     INIT BLANK
            CHARACTER*76     RFN      ! R72 FILENAME.RAWCASE     INIT BLANK
            INTEGER*4        LFN      ! I4  FILENAME.LENGTH      INIT 0
            CHARACTER*32     USN     !! U32 SECTION-NAME-UP.CASE INIT BLANK
            CHARACTER*32     RSN      ! R32 SECTION-NAME RAWCASE INIT BLANK
            INTEGER*4        LSN      ! I4  SECTION-NAME-LENGTH  INIT 0
            CHARACTER*32     UTN     !! U32 TAG-NAME-UP.CASE     INIT BLANK
            CHARACTER*32     RTN      ! R32 TAG-NAME-RAWCASE     INIT BLANK
            INTEGER*4        LTN      ! I4  TAG-NAME-LENGTH      INIT 0
            CHARACTER*80     UTV      ! U80 TAG-VALUE.UP.CASE.IN INIT BLANK
            CHARACTER*80     RTV     !! R80 TAG-VALUE.RAWCASE.IN INIT BLANK
            INTEGER*4        LTV      ! I4  TAG-VALUE-LENGTH     INIT 0
            CHARACTER*80     RWL      ! R80 TAG-RAW.WHOLE.LINE   INIT BLANK
            INTEGER*4        LWL      ! I4  TAG-RAW.WHOLE.LENGTH INIT 0
            INTEGER*4        NWL      ! I4  LIN.#.IN.ORIG.FILE   INIT 0
            LOGICAL*4        SET      ! L4  TAGRICL   SET YET ?  INIT FALSE
            LOGICAL*4        USE      ! L4  TAGRICL  USED YET ?  INIT FALSE
          END STRUCTURE
C
C
      PARAMETER                   (N1000=200)
      RECORD /STAGRICL/   TAGRICL (N1000)  ! 1000.MAX TAG.NAMES.PER.FILE
Obviously, F2C complains about structure STAGRICL in TAGLINE.INS.
Thank you so much for your help and guidance.
Steve_Lionel
This forum is not related to F2C, which is something I can't recommend that ANYONE use in 2020. Even when F2C was reasonable to use, it wasn't intended as a tool for conversion but rather as a way to compile FORTRAN code if you had a C compiler but not Fortran.
I will comment that this code is NOT FORTRAN 77. STRUCTURE, RECORD, INCLUDE, INTEGER*4 are all extensions to F77. STRUCTURE/RECORD, in particular, was a DEC extension that was not commonly implemented in F2C's time.
That said, if you know anything about C, and if you don't you're doomed to failure here, it is straightforward to reinterpret this as a C struct.
heysiattalab__saeed
Hi Steve,
Thank you for your reply. What tool would you recommend for converting a HUGE FORTRAN code to C ? The code is years of development and I can not really rewrite in C, as it would take a lot of time.
JohnNichols
Valued Contributor III
heysiattalab, saeed wrote:
Hi Steve,
Put Fortran in  DLL and then use a C calling program  --
mecej4
Before you can use f2c, you would need to convert your source code to standard Fortran 77, or the dialect of it that f2c understands.
Take note of this statement from page 2, para 1 of the f2c documentation at http://www.netlib.org/f2c/f2c.pdf :
Thus the C output of f2c would probably be something of a nightmare to maintain as C; it would be much more sensible to maintain the original Fortran, translating it anew each time it changed.
Do not undertake translation of a large body of code without careful planning and assessment.You may well spend several months, only to reach a point where you find out that the task is impossible or not worthwhile.
JohnNichols
What meccej4 is saying in very polite language is == this is a really bad idea and one should take it after climbing Mt Everest and considering it would be harder than that.
Barbara_P_Intel
I've heard anecdotes complaining about performance from developers who ported applications from Fortran to C.  They have to work hard to get C to match the runtime performance of the Fortran code.
Steve_Lionel
I always recommend against converting a working program from one language to another. It usually ends badly. You are certain to introduce bugs or other unwanted behavior. Certainly if one was to do this, an ancient translator such as F2C is the worst possible approach.
Why do you want to do this? What do you think it will accomplish? It certainly won't make the code any more maintainable.
heysiattalab__saeed
This code is running a piece of hardware and porting FORTRAN to C is a part of renovation project for software along the hardware which is very old. I am not a big fan of code conversion myself but it has been assigned to me. I am concerned with run time errors, performance, and bad behavior after conversion and it might be also impossible after a few months of work.
Steve_Lionel
What is the purpose of the language conversion? Why can't the code stay in Fortran?
