I have been trying to install Intel OneAPI toolkit with Visual Studio 2017 on Windows 10 in order to use the Fortran compiler. I followed the instructions by installing VS 2017 (I made sure to select C++ Desktop development). I then installed Intel OneAPI toolkit 2022.2 (the Base first then the one with Fortran) which should be compatible with the VS 2017 version. The problem is that when I launch VS, there is no option to select a Fortran project. Is there anything else I need to do to make Fortran work with VS?
Hi, I have now deleted VS 2017 because I was able to make VS 2022 work with Intel so I can't provide the requested info. Thank you for your willingness to help.
Can you provide the copy of info from inside VS Help>About Microsoft Visual Studio. That will give me more info to respond to your issue.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
