When I run a program using Ctrl+F5, in Release mode,afterBuild succeeded, the console window only flashes once without running it. If in Debug mode, no problem. But the same code works well on some other computers. I'm wondering whether it depends on some special settings. All test pcs areusing Vista, IVF 11.0.066. Many thanks for any help!
I found I have to manually run the .exe file in the 'Release' folder. This does not happenon some other computers. Why?
Which Visual Studio version are you using?
Quoting - Steve Lionel (Intel)
All Microsoft Visual Studio 2008.
Another thing, Iwonder whether IVF 11.0.066 worksin Win7 system.It seemsit cannotbe builtcorrectly.Do I have to update the IVF?
Thanks for your help.
The correction of Win7 installation bug occurred with 11.1.048. Discussion of that is still present at the top of the C++ forum (not amended to point out that the latest version should work too); it seems to have fallen off the Fortran forum.
As Tim says, 11.1.048 or later is the minimum supported on Windows 7. I suppose I should re-stick that thread...
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
Topic Options
