Slow deallocation in derived type data
De_Vita__Paolo
I found a very slow speed during a deallocation of a derived data type that I can not fix.
I'm using IVFC 16.0.3.207 for Windows, with default release compiler options.
Here below an exemplification of my problem:
program test_dealloc
implicit none
integer(kind=4) :: n1 = 5827396
integer(kind=4) :: n2 = 75
integer(kind=4) :: i
type ddata
complex(kind=4), dimension(:,:), allocatable :: elem
end type ddata
type(ddata), pointer, dimension(:)   :: ddata_p
real(4) time1,time0
! start
time0=secnds(0.0)
allocate(ddata_p(n1))
do i=1,n1
allocate(ddata_p(i)%elem(n2,n2))
enddo
time1=secnds(time0)
print*, ' '
print*, 'Allocation time', time1
! computation kernel
time0=secnds(0.0)
do i=1,n1
deallocate(ddata_p(i)%elem)
enddo
deallocate (ddata_p)
time1=secnds(time0)
print*, ' '
print*, 'Deallocation time', time1
end
I've used the function secnds for the timing and the print on the screen is:
>test_dealloc.exe
 Allocation time   15.62891
 Deallocation time   4075.336
The machine is a XEON E5-2690 x64 with 192 GB of RAM, the OS is Windows Server 2008 R2 Enterprise.
From the task manager the allocated memory is around 44GB. The time for the deallocation is very large, much more than the allocation one and also much more of the computation kernel where the data structure is filled.
Is there any possibility to reduce such a deallocation time?
Thank you very much. Regards
Paolo
Andrew_Smith
Valued Contributor I
This issue sounds serious and deserves consideration by Intel.
John_Campbell
New Contributor II
"From the task manager the allocated memory is around 44GB"
I did a calc for n1 = 5827396 and n2 = 75 and get an estimate of 244 GB. I suggest you try n1 = 5827396/100, use the following changes and run with task manager.
  integer(kind=8) :: siza, sizi, sizet
  real*4 gb
  ! start
  time0 = secnds(0.0)
  allocate (ddata_p(n1))
  write (*,*) 'allocate ddata_p size =', sizeof (ddata_p)
  sizet = 0
  do i=1,n1
    allocate (ddata_p(i)%elem(n2,n2))
    sizet = sizet + sizeof ( ddata_p(i)%elem )
  enddo
  time1 = secnds(time0)
  gb = sizet / 1024.**3
  write (*,*) 'fill ddata_p size =', sizet, gb  ! c_sizeof (ddata_p)
  read (*,*) gb
De_Vita__Paolo
Thank you John,
You are rigth, the real size of the data structure is 244 GB, in fact if I try to initialize the variable I read in the task manager the same allocated memory that you read too.
I made this test on bigger machine (Intel Xeon Gold 6144 with 684 GB RAM OS Windows Server 2016 Datacenter) adding the following initialization:
time0=secnds(0.0)
do i=1,n1
ddata_p(i)%elem = 0
enddo
time1=secnds(time0)
print*, ' '
print*, 'Setting time', time1
And I obtained these new values:
test_dealloc_setting.exe
 Allocation time   14.67578
 Setting time   79.22656
 Deallocation time   3202.836
The deallocation time is still very large.
Paolo
jimdempseyatthecove
This looks like an issue with the C++ heap manager and/or virtual memory paging due to fragmentation issues. Try deallocating in reverse order of allocation:
time0=secnds(0.0)
do i=n1,1,-1
enddo
time1=secnds(time0)
print*, ' '
Jim Dempsey
jimdempseyatthecove
Also, If you have memory deallocation debugging enabled (e.g. valgrind, or Windows debug C Runtime Library) this may have an effect on free (deallocate).
Jim Dempsey
De_Vita__Paolo
Hi Jim,
I tried to deallocate in reverse order but nothing changed.
Regarding the compiler options, I've left the default ones for the release configuration, that are (from the command window of the compiler):
/nologo /O2 /module:"x64\Release\\" /object:"x64\Release\\" /Fd"x64\Release\vc100.pdb" /libs:dll /threads /c
Paolo
LRaim
One possible solution is:
1) change elem into a pointer instead  of an allocatable array.
2) allocate a single block of n1*n2*n2 elements.
3) set  ddata_pi(i)%elem to the initial element of each n2*n2 matrix
In this case you will have a single de-allocation.
De_Vita__Paolo
Hi Luigi,
Thank you for the suggestions. About the options:
1) I tried with pointer but no real change
2) That would be really the worst solution for my case because in the real code n2 is depending from n1 and I don't know in advance the final dimensione of the data, so the derived structure would be the best option for my application.
3) I didn't understand, can you explain better please? (or make an example)
Paolo
LRaim
Sorry for the hurry in answering.
The 3 points, I suggested, must be implemented together to get a possible solution .
About your point 2). The possible solution can be applied if  n2(i) for each i can be computed in a previous do-loop.
About your point 3). I do not have time to set-up an example. This step is similar to set N pointers to each column of a NxN matrix (after the matrix has been allocated).
jimdempseyatthecove
Do you have VTune available to perform a performance test?
About the only thing left to check is there used to be an Intel Floating License check issue causing long delays in a program. Though I do not recall it being related to deallocation.
Jim Dempsey
Andrew_Smith
This is a very serious 300 fold drop in performance. Why has it not been aknowledged by Intel as an issue?
andrew_4619
I took the program in #1 and built it. I reduced n1 by a factor of 100 because the machine had nowhere near the memory you asked for.
The allocation was 0.21s and the dealloc 0.08s. Our machines will have different speeds but broadly speaking the alloc time is in proportion with your bigger n1 value, the dealloc time however is not and is orders out!!!!
I would suggest running your test at several increasing values of n1 I guess we will see some threshold value at which there is a step change in the dealloc time. This might show something interesting.
The limit (if that is what we see) might be a function of your windows and/or hardware or it may be some limit within the compiler.....
John_Campbell
New Contributor II
My initial thoughts we the large delay was due to a virtual memory event being initiated during deallocation. Physical memory is not used during allocation, but when the array is being used, perhaps at deallocation. I notice the initialisation phase has now been added to the tester, which appears to indicate the deallocation delay is not associated with virtual memory usage. Given the memory sizes being tested, I am also not able to reproduce this problem. The luxury of having this problem !
