Iam usingIntel Visual Fortran 11.0.066 in VS 2008 (v. 9.0.30729.1 SP). Theprojects I have tried to compiledo sook. The problem arises when I try compile using the auto-parallelization(/Qparallel) option. I have to tried to compile three codes so far and all of them fail with the same message:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
One another piece of information is that the problem also arises only when I try to compile with auto-parallelization in the Release mode. In the Debug mode, the compilation proceeds ok with auto-parallelization.
Has anyone encountered any similar occurances?I would much appreciate any help.
RDS
RDS
This is a generic message that can have many possible causes, nearly all of them compiler bugs. Please provide us with test cases and we'll be glad to investigate.
Thanks for the message, Steve.
Unfortunately, I am unable to share the code. I shall try to see if I canreproduce the error with a similar but shareable code and I shall try to post back.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Topic Options
