ifort and fedora 15
simonefe
I need a compiler ifort to i686 machines, what is the correct version should I download? My linux is fedora 15.
TimP
If your linux is i686, (e.g. uname -a) that's a 32-bit linux. If it's x86_64, and you have installed g++ development system, you should be able to install intel64 compilers. You would require 32-bit g++ in addition to 64-bit g++ to install Intel ia32 compilers on x86_64.
Steven_L_Intel1
The current version supports Fedora 15. That would be Intel Fortran Composer XE 2011. I recommend the latest update, which is #10 at this time. You'll usually get pointed to the latest version by default when you download.
simonefe
But, I tried to install the version (l_fcompxe_intel64_2011.10.319) and got the following response:
"The contents of this installation package do not match the architecture of this system. Please check to be sure you are using the correct package and running it on the correct system type."
Also tried the 32 bit version and got:
"Detected operating system is not supported. Supported operating systems for this release include:
- Red Hat Enterprise Linux* 4.0, 5.0, 6.0 (IA-32/Intel 64)
- Fedora* 15 (IA-32/Intel 64)
- SuSE Linux* Enterprise Server* 10.x, 11.0 SP1(IA-32/Intel64)
- Asianux* Server 3.0, 4.0 (IA-32/Intel 64)
- Ubuntu* 10.04 LTS, 11.04 (IA-32/Intel 64)
- Debian 6.0 (IA-32/Intel 64)
- Pardus 2011.2 (Intel 64)"
Any other suggestions?
TimP
If you are running the 32-bit linux, you can install only the ia32 compiler. If you are running Fedora 15 but it's not recognized, that looks like a bug, but you should be able to accept an unsupported install. Any further installation issues not covered by stated prerequisites also would be reportable bugs.
simonefe
Mylinuxis 64-bit with i686 processor,but it seemsthat theifortaccepts only thex64 proce ... soclaimsof different structure...
Isthis is thereasonIcannotinstallifort?
TimP
simonefe
perfect! I installed g + + and composer and installed correctly. thank you
