ifort: command line remark #10411: option '-openmp' is deprecated and will be removed in a future release.
Vijay_K_1
Hello All, I have been facing and issue with respect to Intel Fortran complier while compiling a program called TIEGCM. Which is an open source application.
/opt/intel17/compilers_and_libraries_2017.0.098/linux/mpi/intel64/bin/mpif90 -fc=ifort -r8 -heap-arrays -I. -I/opt/tiegcm2.0/tiegcm_trunk/src -I/usr/local/netcdf-4.1.3/include -I/opt/esmf/esmf/DEFAULTINSTALLDIR/mod/modO/Linux.intel.64.mpiuni.default -I/opt/esmf/esmf/DEFAULTINSTALLDIR/include  -O3  -DLINUX  -DMPI  -c -o output.o /opt/tiegcm2.0/tiegcm_trunk/src/output.F
ifort: command line remark #10411: option '-openmp' is deprecated and will be removed in a future release. Please use the replacement option '-qopenmp'
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(437): error #6633: The type of the actual argument differs from the type of the dummy argument.   [RHO]
     |  diags(ix)%units,rho,diags(ix)%levels,lev0,lev1,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(459): error #6633: The type of the actual argument differs from the type of the dummy argument.   [QJI_TN]
     |  diags(ix)%units,qji_tn(lev0:lev1-1,lon0:lon1),diags(ix)%levels,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(494): error #6633: The type of the actual argument differs from the type of the dummy argument.   [TEC]
     |  diags(ix)%units,tec(:),'lon',lon0,lon1,'lat',lat,lat,0)
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(520): error #6633: The type of the actual argument differs from the type of the dummy argument.   [UI]
     |    diags(ix)%units, ui(:,:,lat),diags(ix)%levels,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(548): error #6633: The type of the actual argument differs from the type of the dummy argument.   [VI]
     |    diags(ix)%units, vi(:,:,lat),diags(ix)%levels,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(576): error #6633: The type of the actual argument differs from the type of the dummy argument.   [WI]
     |    diags(ix)%units, wi(:,:,lat),diags(ix)%levels,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(599): error #6633: The type of the actual argument differs from the type of the dummy argument.   [TOTAL_HEAT]
     |  diags(ix)%units,total_heat(lev0:lev1-1,:),diags(ix)%levels,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(621): error #6633: The type of the actual argument differs from the type of the dummy argument.   [CO2_COOL]
     |  diags(ix)%units,co2_cool,diags(ix)%levels,lev0,lev1,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(643): error #6633: The type of the actual argument differs from the type of the dummy argument.   [NO_COOL]
     |  diags(ix)%units,no_cool,diags(ix)%levels,lev0,lev1,
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(666): error #6633: The type of the actual argument differs from the type of the dummy argument.   [SIGMAPED]
     |  diags(ix)%units,sigmaped(lev0:lev1-1,lon0:lon1),
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(689): error #6633: The type of the actual argument differs from the type of the dummy argument.   [SIGMAHAL]
     |  diags(ix)%units,sigmahal(lev0:lev1-1,lon0:lon1),
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(711): error #6633: The type of the actual argument differs from the type of the dummy argument.   [LAMDAPED]
     |  diags(ix)%units,lamdaped(lev0:lev1-1,lon0:lon1),
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(733): error #6633: The type of the actual argument differs from the type of the dummy argument.   [LAMDAHAL]
     |  diags(ix)%units,lamdahal(lev0:lev1-1,lon0:lon1),
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(759): error #6633: The type of the actual argument differs from the type of the dummy argument.
     |    diags(iex)%units,exyz*100.,diags(iex)%levels,lev0,lev1,'lon',
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(763): error #6633: The type of the actual argument differs from the type of the dummy argument.
     |    diags(iey)%units,exyz*100.,diags(iey)%levels,lev0,lev1,'lon',
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(767): error #6633: The type of the actual argument differs from the type of the dummy argument.
     |    diags(iez)%units,exyz*100.,diags(iez)%levels,lev0,lev1,'lon',
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(792): error #6633: The type of the actual argument differs from the type of the dummy argument.   [BXYZ]
     |    diags(ibx)%units,bxyz,'lon',lon0,lon1,'lat',lat,lat,0)
/opt/tiegcm2.0/tiegcm_trunk/src/diags.F(795): error #6633: The type of the actual argument differs from the type of the dummy argument.   [BXYZ]
     |    diags(iby)%units,bxyz,'lon',lon0,lon1,'lat',lat,lat,0)
It goes on ...
Kindly Help !!
I
jimdempseyatthecove
Has nothing to do with -openmp.
Can you show the complete Fortran statement that is producing the error?
Appears to be a Fixed Format continuation line.
Note, also show the subroutine/function declaration and/or interface.
This error appears when the argument on a CALL (or function use) does not match the argument type/rank/size specified in the subroutine/function.
Jim Dempsey
Steven_L_Intel1
What are you asking for help with?
The initial remark about -openmp should be self-explanatory. Because of the confusion with -o we have created an alternate option -qopenmp we suggest you use instead.
The remaining errors suggest coding errors in the application where arguments passed to procedures don't follow the language rules for how they should match in "type, kind and rank" with the called procedure. You evidently have the source for this application so you should match up the arguments and see how they are declared.
loza__nayelli
Good day!
I contact you because I am having issues when the HWRF-GSI compilation process.
I am using  INTEL IFORT, ICC, ICPC VERSION 19.1.1.217
the system indicates the following error:
ifort: command line error: option '-openmp' is not supported. Please use the replacement option '-qopenmp'
I am looking for all kinds of bibliography and forums but I have not been able to find a possible solution to resolve it yet.
Can you help me or have any idea for possible solution?.
Thank you very much for your support.
Steve_Lionel
The error message tells you exactly what to do. Is it unclear?
Several years ago, Intel removed the -openmp option because it conflicted with -o. The spelling is now -qopenmp. Edit your build script and change any reference of -openmp to -qopenmp.
loza__nayelli
Good day,
Thank you very much for reply my message, yes the error message is unclear it doesn´t say exactly what I have to do.
Ok!!! Thank you very much for your support I' ll try to change in the makefile the reference of -openmp to -qopenmp.
Greetings!
