ipo: error #11018: Cannot open C:\Program leading to fatal error LNK1107
Ashby__Joe
Einsteiger
5.487Aufrufe
So I loaded up visual studio 2012 and created a new Fortran console application with the example code. I tried to build it just to check everything was working and I get this in the build:
1>------ Build started: Project: Console1, Configuration: Debug Win32 ------
1>Linking...
1>ipo: error #11018: Cannot open C:\Program
1>C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\amd64\link.exe : fatal error LNK1107: invalid or corrupt file: cannot read at 0x2E8
1>
1>Build log written to  "file://c:\users\XXXXXX\documents\visual studio 2012\Projects\Console1\Console1\Debug\BuildLog.htm"
1>Console1 - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
buildlog attached.
Can anyone please help? It looks like I have a path somewhere that's not quoted but I don't know where to find it.
Visual Studio 2012
Intel Composer 2013 SP1
16 Antworten
mecej4
Geehrter Beitragender III
5.487Aufrufe
Please attach the build log. You may have an improper path in %LIB% or a related environment variable.
Ashby__Joe
Einsteiger
5.487Aufrufe
Hi mecej4, buildlog attached as a .txt here. Where could I look to check the paths?
mecej4
5.487Aufrufe
I don't understand why IPO is being used in a debug build, and the build log that you provided does not show any information on the compilation phases, since it shows only information about the linking stage. Please try "clean" and "build".
Ashby__Joe
Einsteiger
5.486Aufrufe
Sorry for the delay, I did the clean build and have attached the new log
Steve_Lionel
5.486Aufrufe
You're building a 32-bit program but invoking the 64-bit linker. That's not right.
In VS, select Tools > Options > Intel Compilers and Tools > Visual Fortran > Compilers. With the Win32 tab active, click Reset... Click on the x64 tab and click Reset... Click OK.
Ashby__Joe
Einsteiger
5.486Aufrufe
Hi Steve,
That did not seem to change anything, it is still calling the 64-bit version. Maybe my PATH is wrong in the Windows environment variables?
Steve_Lionel
5.486Aufrufe
Go back to that Compilers tab. Click on the ... next to "Executables". Copy the text that is displayed and paste it into a reply here.
Next, open a command prompt window (not a Fortran build environment window) - Press Windows-X and select Command Line (or PowerShell if it appears). Set default (cd) to a writeable folder (not under Windows or Program Files) and type:
set path > path.txt
Attach the path.txt to your reply here.
Ashby__Joe
Einsteiger
5.486Aufrufe
$(IFortInstallDir)bin\ia32;$(VSInstallDir)Common7\IDE;$(VCInstallDir)BIN;$(VSInstallDir)Common7\Tools;$(VSInstallDir)Common7\Tools\bin;$(FrameworkDir)$(FrameworkVersion);$(WindowsSdkDir)bin\x86;$(PATH)
path.txt attached
mecej4
5.486Aufrufe
I see the following potential problems in your %PATH%:
"C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\intel64" appears twice.
"C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin" appears once; this directory contains only batch files and subdirectories.
"C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\ia32" contains tools needed for 32-bit compilations, but is not included in %PATH%.
Ashby__Joe
Einsteiger
5.486Aufrufe
I have added "C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\ia32", and removed "C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin", however the problem is still occuring.
Steve_Lionel
5.486Aufrufe
You did the "set path" from a command prompt that was NOT a "Fortran build environment" prompt, as I requested? You should not have any of the \bin folders in PATH. How did they get there?
Ashby__Joe
Einsteiger
5.486Aufrufe
Yes I did. I added those folders as I was told it was necessary for the integration of ifort and link with my finite element modelling software ABAQUS which uses fortran for it's user subroutines.
Steve_Lionel
5.486Aufrufe
Take them out - they don't belong there. The better choice is to use one of the "Fortran build environment" shortcuts or make your own with a call to ifortvars.bat with appropriate options. What you have done is subverted the way the VS integration selects which executables to use.
Ashby__Joe
Einsteiger
5.486Aufrufe
Okay, I have removed all of these from the Path, however my problem is still the same. Do I need to reconfigure/reinstall anything?
Steve_Lionel
5.486Aufrufe
Please reboot first. I would also suggest that you set Tools > Options > Intel Compilers and Tools > Visual Fortran > General > Show Environment in Log to True, do a rebuild, ZIP the buildlog.htm and attach the zip to a reply here.
Ashby__Joe
Einsteiger
5.486Aufrufe
Hi Steve (and mecej4),
Thank you so much for your help, it was indeed just the PATH that was messing things up and I have got everything working, including the ABAQUS integration.
Thanks again,
Joe
Antworten
