- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Quartus Prime Version 19.1.0 Build 670 09/22/2019 SJ Standard Edition with Matlab R2013a.
When a Simulink model is compiled in Quartus and archived to produce a portable IP block, the '.qip' files generated contain absolute paths only where every vhdl file is added four times.
I am unable to find a method to force relative paths to be created.
I have attached an example from the Quartus install directory with
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi I have attached an image of the text of my request as the forum corrupts it each time i type it in
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
As I understand it, you have some inquiries related to the absolute path of the DSP Builder generated RTL. Please allow me some time to look into it and perform issue replication. Once replicated, I will try to see if can find any workaround. If not, will further consult Factory on this. I will update you on the progress by mid of next week. Please ping me if you do not hear back from me. Thank you.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
For your information, as I tested generating the rtl for the demo_nco example in the DSP Builder, I observe in the .qip file, the relative path but not absolute path is used. As I tested enabling the "Use separate work directory for Quartus Prime project", the generated .qip file seems will use absolute path.
As a workaround, would you mind to try disabling the "Use separate work directory for Quartus Prime project" to see if it work for you to generate relative path in .qip file.
Please let me know if there is any concern. Thank you.
Chee Pin
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Good morning and thank you for getting back to me.
The work around does give relative paths, but it still adds every file four times?
I will try to use this as a work around in the short term.
Will you be reporting this as a bug to the development team?
Best regards
Simon
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Simon,
Thanks for your help and understanding. Regarding the same file being duplicated 4 times, this seems to be a bug. I will report this to the Factory. Sorry for the inconvenience.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi
Thanks you for getting back to me.
If you could also report that it is not possible to get relative paths when a seperate quartus directory is selected it would be appreciated.
This could be a very useful feature to simplify archiving, but only if it still generates relative paths.
Best regards
Simon
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Yes, I have also highlighted the absolute path issue. Thank you.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
