Intel® High Level Design
722 Discussions
FPGA OpenCL SDK crashed v18.1.0
DongWang-BJTU
Hi, I have encountered the follow error while using OpenCL SDK v18.1.0 with a10_ref board:
It seems that it has something to do with file naming, the message has not been included in the user's manual. Software simulation works fine.
DongWang-BJTU
Problem solved. Shortened the name of the kernel from 10 characters to 6.
MuhammadAr_U_Intel
Hi, Are you trying to compile any of the example provided with OpenCL compiler release ? or you are compiling your custom Kernel ? Internal Error is most probably due to a issue in compiler. Thanks, Arslan
DongWang-BJTU
