Intel® High Level Design
722 ディスカッション
Time voilate with GPIO/DDIO in Arria 10
ljian50
ビギナー
2,071件の閲覧回数
I have 8 groups 64 lines LVDS input, and 3 group of them received with GPIO, 5 group received with SERDES IP, but setup and hold time is not satisfyied
0 件の賞賛
7 返答(返信)
ljian50
ビギナー
2,003件の閲覧回数
Help
ShafiqY_Intel
従業員
2,003件の閲覧回数
Hi lijian50,
Please allow me some time to look into it.
I'm downloaded and compiled your design.
ShafiqY_Intel
従業員
2,003件の閲覧回数
Hi ljian50,
When you say "setup and hold time is not satisfied", can you elaborate more?
How much you get for setup and hold time?
ljian50
ビギナー
2,003件の閲覧回数
This is one time run result. I use PLL phase in SDC file to adjust the timing result, but never succed. Hold time even is larger than 3.571ns(280MHz). I don't know how to satisfy the timing . Is there anything else i forget to do with my SDC file?timing_result.png
ljian50
ビギナー
2,003件の閲覧回数
If DDIO sample with the input clock from pin, and I change the data time delay from pin to DDIO input use INPUT_DELAY_CHAIN in .QSF file, hold time is never satisfied. The result is belowclk_pin_timing.png
xytech
新規コントリビューター I
2,003件の閲覧回数
@ShafiqY_Intel​
Hi ,I am a colleague of ljian50, pls see AFE5809 datasheet section 7.10 and 8.3.8 for LVDS time requirements. (https://www.ti.com.cn/lit/ds/symlink/afe5809.pdf?ts=1591957198622&ref_url=https%253A%252F%252Fwww.ti.com.cn%252Fproduct%252Fcn%252FAFE5809
We heard that A10 IC have some problem related to silicon and can not close the timing for DDIO, but not sure if this is true.
@KhaiY_Intel​ I noticed you answered on a similar question some months ago, would you pls also help take a look on this question? Thanks!
https://forums.intel.com/s/question/0D50P00004Q8inFSAR/using-ddioin-to-read-adc-data-and-timing-analysis
ljian50
ビギナー
2,003件の閲覧回数
返信
