OpenCV is not showing improvement when running with IPP
eitan_s_
Hi All,
I installed latest IPP product and I have video processing code in OpenCV. I recompiled OpenCV with flag WITH_IPP however I don't see any performance improvement. What I'm missing ? How can I tell OpenCV is detecting the IPP ?
Pavel_V_Intel
Now after make finish I'm getting error:
You need to apply this patch: https://github.com/opencv/opencv/pull/8109/files
Jing_Xu
You may enable IPP on OpenCV by passing switches "-D WITH_IPP=ON -D IPPROOT=<Your IPP Location>" to cmake command like the following.
cmake -D WITH_IPP=ON -D IPPROOT=<Your IPP Location> .
For more detailed information, please refer to https://software.intel.com/en-us/articles/enabling-ipp-on-opencv-windows-and-linux-ubintu
To confirm how your OpenCV works with IPP, please check in version_string.tmp under your OpenCV build directory.
Suppose you follow the following official OpenCV installation guide, you will find the version_string.tmp under ~/opencv/release.
  1. Create a temporary directory, which we denote as <cmake_binary_dir>, where you want to put the generated Makefiles, project files as well the object files and output binaries.
  2. Enter the <cmake_binary_dir> and type
    cmake [<some optional parameters>] <path to the OpenCV source directory>
    For example
    cd ~/opencv
    mkdir release
    cd release
    cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ..
  3. Enter the created temporary directory (<cmake_binary_dir>) and proceed with:
    make
    sudo make install
eitan_s_
Thanks for reply. Still not working.
I got the version_string.tmp file.
Why I see ?
Use IPP:                     IPP not found or implicitly disabled\n"
"\n"
"General configuration for OpenCV 3.1.0 =====================================\n"
"  Version control:               unknown\n"
"\n"
"  Platform:\n"
"    Host:                        Linux 4.4.0-59-generic x86_64\n"
"    CMake:                       3.5.1\n"
"    CMake generator:             Unix Makefiles\n"
"    CMake build tool:            /usr/bin/make\n"
"    Configuration:               RELEASE\n"
"\n"
"  C/C++:\n"
"    Built as dynamic libs?:      YES\n"
"    C++ Compiler:                /usr/bin/c++  (ver 5.4.0)\n"
"\n"
"  Video I/O:\n"
"    DC1394 1.x:                  NO\n"
"    DC1394 2.x:                  NO\n"
"    FFMPEG:                      YES\n"
"      codec:                     YES (ver 56.60.100)\n"
"      format:                    YES (ver 56.40.101)\n"
"      util:                      YES (ver 54.31.100)\n"
"      swscale:                   YES (ver 3.1.101)\n"
"      resample:                  NO\n"
"      gentoo-style:              YES\n"
"    GStreamer:                   NO\n"
"    OpenNI:                      NO\n"
"    OpenNI PrimeSensor Modules:  NO\n"
"    OpenNI2:                     NO\n"
"    PvAPI:                       NO\n"
"    GigEVisionSDK:               NO\n"
"    UniCap:                      NO\n"
"    UniCap ucil:                 NO\n"
"    V4L/V4L2:                    NO/YES\n"
"    XIMEA:                       NO\n"
"    Xine:                        NO\n"
"    gPhoto2:                     NO\n"
"\n"
"  Parallel framework:            pthreads\n"
"\n"
"  Other third-party libraries:\n"
"    Use IPP:                     IPP not found or implicitly disabled\n"
"    Use IPP Async:               NO\n"
"    Use VA:                      NO\n"
"    Use Intel VA-API/OpenCL:     NO\n"
"    Use Eigen:                   NO\n"
"    Use Cuda:                    NO\n"
"    Use OpenCL:                  YES\n"
"    Use custom HAL:              NO\n"
"\n"
"  OpenCL:\n"
"    Version:                     dynamic\n"
"    Include path:                /home/eitans/opencv-3.1.0/3rdparty/include/opencl/1.2\n"
"    Use AMDFFT:                  NO\n"
"    Use AMDBLAS:                 NO\n"
"\n"........
Jing_Xu
Your log indicates that OpenCV was not built with IPP support.
Please follow the following steps to compile OpenCV with IPP.
Suppose your root directory of IPP is <IPPROOT>. It should be similar to "/opt/intel/compilers_and_libraries(_2017 or _2017.x.yyy or null)/linux/ipp".
    For example
    cd ~/opencv
    mkdir release
    cd release
    cmake -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_INSTALL_PREFIX=/usr/local -DWITH_IPP=ON -DIPPROOT=<IPPROOT> ..
    make
    sudo make install
If these do not work for your compiling, could you share more detailed information like your command line history to compile OpenCV, and where is your IPP root directory, and so on, please?
eitan_s_
Specified DIPPROOT=/opt/intel/ipp
Now a version is detected but I'm getting failure.
Any advise how to resolve those ?
-- found IPP: 2017.0.0 [2017.0.0]
-- at: /opt/intel/ipp
-- Can't find IPP library: m at /opt/intel/ipp/lib/intel64/libippm.a
CMake Error at cmake/OpenCVFindIPP.cmake:204 (message):
  Intel compiler EM64T libraries not found
Call Stack (most recent call first):
  cmake/OpenCVFindIPP.cmake:254 (ipp_detect_version)
  cmake/OpenCVFindLibsPerf.cmake:37 (include)
  CMakeLists.txt:562 (include)
-- Can't find compiler library: irc at /opt/intel/compilers_and_libraries_2017.0.098/linux/compiler/lib/intel64/libirc.so
-- Can't find compiler library: imf at /opt/intel/compilers_and_libraries_2017.0.098/linux/compiler/lib/intel64/libimf.so
-- Can't find compiler library: svml at /opt/intel/compilers_and_libraries_2017.0.098/linux/compiler/lib/intel64/libsvml.so
Jing_Xu
Could you share us your compiling command history, CMakeCache.txt and version_string.tmp with us, please? (Starting from unzip opencv from the zip file)
Besides, did you install the IPP with Intel System Studio or Intel Parallel Studio or using standalone package?
eitan_s_
The main command I'm using is:
cmake -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_INSTALL_PREFIX=/usr/local -DWITH_IPP=ON -DIPPROOT=/opt/intel/ipp ..
Also attached the requested files.
Thanks, Eitan
Jing_Xu
It seems to be all right from these two files.
Have you tried to run make to compile OpenCV after the cmake command?
eitan_s_
yes, make command fail.
Notice that I have errors for cmake
Maybe I install IPP incorrectly ?
How can I check that IPP is install correctly ?
Can you point me to the install instructions for IPP over ubuntu ?
-- Checking for module 'libavresample'
--   No package 'libavresample' found
-- Checking for module 'libgphoto2'
--   No package 'libgphoto2' found
eitan_s_
attaching cmake output and error log files
Pavel_V_Intel
Hi Eitan,
These libraries shouldn't be required for IPP 2017, build scripts are a little out of date.
Can you also attach your make log?
eitan_s_
The main problem is that I'm not getting a Makefile so I can't run make :(
eitan_s_
The macro in cmake file OpenCVFindIPP.cmake that fail when called with name='m'
 macro(_ipp_add_library name)
    # dynamic linking is only supported for standalone version of IPP
    if (BUILD_WITH_DYNAMIC_IPP AND NOT HAVE_IPP_ICV_ONLY)
      set(IPP_LIB_PREFIX ${CMAKE_SHARED_LIBRARY_PREFIX})
      set(IPP_LIB_SUFFIX ${CMAKE_SHARED_LIBRARY_SUFFIX})
    else ()
      set(IPP_LIB_PREFIX ${CMAKE_STATIC_LIBRARY_PREFIX})
      set(IPP_LIB_SUFFIX ${CMAKE_STATIC_LIBRARY_SUFFIX})
    endif ()
    if (EXISTS ${IPP_LIBRARY_DIR}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX})
        # When using dynamic libraries from standalone IPP it is your responsibility to install those on the target system
        list(APPEND IPP_LIBRARIES ${IPP_LIBRARY_DIR}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX})
      else ()
        add_library(ipp${name} STATIC IMPORTED)
        set_target_properties(ipp${name} PROPERTIES
          IMPORTED_LINK_INTERFACE_LIBRARIES ""
          IMPORTED_LOCATION ${IPP_LIBRARY_DIR}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX}
        list(APPEND IPP_LIBRARIES ipp${name})
        if (NOT BUILD_SHARED_LIBS)
          # CMake doesn't support "install(TARGETS ${IPP_PREFIX}${name} " command with imported targets
          install(FILES ${IPP_LIBRARY_DIR}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX}
                  DESTINATION ${OPENCV_3P_LIB_INSTALL_PATH} COMPONENT dev)
          string(TOUPPER ${name} uname)
          set(IPP${uname}_INSTALL_PATH "${CMAKE_INSTALL_PREFIX}/${OPENCV_3P_LIB_INSTALL_PATH}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX}" CACHE INTERNAL "" FORCE)
          set(IPP${uname}_LOCATION_PATH "${IPP_LIBRARY_DIR}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX}" CACHE INTERNAL "" FORCE)
        endif()
      endif()
    else()
      message(STATUS "Can't find IPP library: ${name} at ${IPP_LIBRARY_DIR}/${IPP_LIB_PREFIX}${IPP_PREFIX}${name}${IPP_SUFFIX}${IPP_LIB_SUFFIX}")
    endif()
  endmacro()
eitan_s_
By the way when dropping "DIPPROOT" and just running - cmake -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_INSTALL_PREFIX=/usr/local -DWITH_IPP=ON ..    than cmake works well and also make.
--     Use IPP:                     9.0.1 [9.0.1]
--          at:                     /home/eitans/opencv/build/3rdparty/ippicv/ippicv_lnx
--     Use IPP Async:               NO
--     Use VA:                      NO
--     Use Intel VA-API/OpenCL:     NO
--     Use Lapack:                  NO
--     Use Eigen:                   NO
--     Use Cuda:                    NO
--     Use OpenCL:                  YES
--     Use OpenVX:                  NO
--     Use custom HAL:              NO
The problem in that case is that I don't see any improvement later on when using OpenCV and so I assume it is not using the IPP product :(
eitan_s_
Looking more in OpenCVFindIPP.cmake I see difference between ICV and standalone IPP
Any idea why we have this difference ?
We are failing on     _ipp_add_library(m)
if(HAVE_IPP_ICV_ONLY)
    _ipp_add_library(icv)
  else()
    _ipp_add_library(core)
    _ipp_add_library(s)
    _ipp_add_library(i)
    _ipp_add_library(cc)
    _ipp_add_library(cv)
    _ipp_add_library(vm)
    _ipp_add_library(m)
eitan_s_
eitan_s_
Pavel_V_Intel
You are using release OpenCV 3.1, right? Can you update to 3.2? As I remember there were compatibility updates for IPP 2017. I can configure OpenCV 3.2 with IPP 2017.0.0 without any problem. There are some building problems, but I can help to fix them.
This is a special IPP package for OpenCV which downloads by default. It has some limitations, but there is no guaranty that you are using any OpenCV function with IPP optimizations at all.
You can check performance difference by using cv::ipp::setUseIPP(bool) function before OpenCV calls.
eitan_s_
After removing the library _ipp_add_library(m) I'm getting error around
message(SEND_ERROR "Intel compiler EM64T libraries not found")
I think the problem is that I'm missing soft link under:   /opt/intel/lib
intel64 ==> intel64_lin
so I added it
eitan_s_
../../lib/libopencv_core.so.3.2.0: undefined reference to `n8_ownsAdd_8u_Bound'
collect2: error: ld returned 1 exit status
apps/version/CMakeFiles/opencv_version.dir/build.make:105: recipe for target 'bin/opencv_version' failed
make[2]: *** [bin/opencv_version] Error 1
CMakeFiles/Makefile2:6905: recipe for target 'apps/version/CMakeFiles/opencv_version.dir/all' failed
make[1]: *** [apps/version/CMakeFiles/opencv_version.dir/all] Error 2
Makefile:160: recipe for target 'all' failed
make: *** [all] Error 2
eitan_s_
[EITANS]  "there is no guaranty" .... is that a general statement or only when using ICV ?
[EITANS] Can you elaborate how to use it and what does it tells me ?
