Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
GFX 4678 driver cause black screen flicker offen in 4k 60hz mode
Dear all
I have a 4k monitor runs at 4k 60hz, and occasionally I got HDMI output lost in standby mode. I have updated the GFX driver to latest .4678, and HDMI firmware to 1.66. but no HDMI lost are solved and I have got many black screen flickers when playback 4k videos and photos. Sometime even in web browsers.
Do some other one have similar problems? I am doubt it may be a driver bug.
Thanks and regards
William Wang
Highlighted
Community Manager
Hello WW6302,
Thank you for contacting Intel Communities.
I am sorry for the inconvenience. I would recommend to keep working on the original thread /message/479752# 479752 where you reported the issue after updating the graphics driver.
Juan V.
Highlighted
Hello All,
I work for Intel Customer Support and I want to let you know that we are aware of screen flashing and/or flickering issue when using 4K resolutions on NUC7ixBN systems.
This issue has been reported and engineering is working on finding a solution for it.
I am trying to locate all community threads related to this issue to refer them back to the following one and consolidate: /message/490689# 490689 NUC7ixBN Screen Flashing/Flickering when using 4K resolutions <</span>/thread/116824 https://communities.intel.com/thread/116824> We will keep this community thread updated with any progress we make.
I apologize for any inconvenience this may have caused or is still causing and I appreciate your help and patience.
Ronny G
