Intel® NUCs
12747 Discussions
Lost Ethernet Connection
PremiumComfort
I am unable to connect to my LAN.  The error is "Unidentified Network - No Internet".  The system was fine on Friday, but on startup Monday the functionality is gone, although WiFi works to connect to the internet.  I require LAN access for connectivity to my NAS, so WiFi is only a stop-gap solution.
Troubleshooting has included:
Rebooting all involved devices.
Remove and automatically discover NIC in the Device Manager
ipconfig
Different network cable, different switch port
Windows & Intel driver updates
Onboard Devices in the BIOS
Recover (re-install) Windows
A few more random things in the middle of each of those, but I think you get the idea.
Model: BOXNUC8i3CYSM1
purchased slightly less than a year ago - but Intel has decided it's past End of Life, so won't support it......... even though it's still under warranty.
LeonWaksman
You may try:
1. Restart the Router.
2. Run the Windows build in Network Troubleshooter.
3. Disconnect the Power Adapter and the CMOS Battery and reconnect them after few minutes.
Leon
