Intel® Optane™ Memory
Avisos
1388 Discusiones
Enabling Optane with Asus Prime z390-a
daath
Novato
4.616 Vistas
Hi there,
I am setting up a new machine with an Asus Prime z390-a motherboard with the latest BIOS (0805 I think it is named).
I have a Samsung 970 Evo Plus in M2_1 and a 32GB Intel Optane stick in M2_2 - In the BIOS both are controlled by RST.
The Optane stick shows up as a regular SSD as you can see in the disk manager screenshot.
The Optane UI shows "No compatible disks for Intel Optane memory (see screenshot).
Attached is also a SSU scan. What am I doing wrong?
I am going to be using the Optane stick on a 7200RPM 8TB disk, but I wanted to get everything going before moving the disk...
Thanks! :)
0 kudos
1 Solución
daath
Novato
4.029 Vistas
Never mind. I must be tired. I uninstalled the Optane software and re-installed the Intel RST v17.0.1.1075 and tried again, this time I actually read the "error" on that latest version and it says: "Your system appears to be Intel Optane memory ready and Intel Optane memory module is present, but no compatible disks to accelerate were detected in your computer. Please install a compatible disk.".
Now I feel stupid. I guess it works, when I eventually attach my HDD :)
Ver la solución en mensaje original publicado
3 Respuestas
daath
Novato
4.029 Vistas
By the way, I tried using the latest RST as well as uninstalling that and installing using SetupOptanememory.exe ...
daath
Novato
4.030 Vistas
YH18
Empleados
2.771 Vistas
Did u have to make any specific BIOS changes to enable the motherboard to identify the Optane memory?
Responder
