Intel® Optane™ Memory
公告
1388 讨论
Intel optane memory 32GB Error Code: 0xA0050055
JRuru
初学者
15,389 次查看
My laptop MSI GL63 8SE have a problem to enable intel optane memory 32GB to accelerated the second HDD drive (Error Code: 0xA0050055)
What should i have to do ?
0 项奖励
1 解答
LeonWaksman
超级用户
14,498 次查看
I agree with Al that manipulating with SATA mode, may cause you to lose your SSD. So, in first place you should prepare a disk backup (image). In the second place as Al advises, you should ask the MSI what to do.
About the SATA mode your laptop is currently set, I think that this is correct mode for Optane Memory (i.e. Intel RST Premium With Intel Optane System Acceleration). The normal SATA mode is AHCI for work without Optane. There are also other posibilities to set RAID or IDE modes for SATA.
Be aware, if you will try to change the SATA mode now, you will lose your system SSD unless, before doing this you should change Windows boot mode to SAFE. If you will boot into Bios while Windows is in SAFE mode, after changing the SATA mode, Windows will not be corrupted. However, you should have full backup of your disk before you are doing this and best ask MSI how to proceed.
Leon
在原帖中查看解决方案
0 项奖励
14 回复数
AlHill
超级用户
14,498 次查看
Either your bios is not setup correctly, or optane is not supported on your laptop.
Contact MSI support for further assistance.
Doc
0 项奖励
JRuru
初学者
14,498 次查看
In my bios setup (SATA Mode Selection) already choose : Intel RST Premium With Intel Optane System Acceleration.
Thanks for the advice
0 项奖励
LeonWaksman
超级用户
14,497 次查看
  1. On the Disk Management image I can see that the Optane Memory Module showing "Not Initialized" state and should be "Online".
  2. Right-click the drive marked "Not Initialized," and select Initialize Disk.
  3. Select GPT (GUID Partition Table) and press OK
Leon
0 项奖励
JRuru
初学者
14,497 次查看
The disk status is now online (GPT) but still not working.
0 项奖励
LeonWaksman
超级用户
14,497 次查看
  1. Could be that there are some residual data on your Optane memory.
  2. Uninstall your Optane Memory Software and reboot your computer.
  3. Right mouse click on Start and then on open Windows PowerShell (Admin). In this window, execute the following commands (press on enter after each command):
  • diskpart
  • list disk
  • select disk 2 (I'm assuming that your Optane drive is #2 as I can see in the attached image of Disk management. Please verify this in the Command Prompt, otherwise drive with your data will be wiped).
  • clean all
  • exit
Reinstall the Optane Software and enable Optane Memory.
Please save image of Optane Memory Software screen, before enabling Optane.
In case of failure, please attached image before and after trying enablement.
Leon
0 项奖励
JRuru
初学者
14,497 次查看
Hai Leon,
I follow your instruction above, clean all disk 2 (intel optane) in windows power shell (admin), but still Error Code: 0xA0050055
Should i update my bios version ?
Jemmy
0 项奖励
Baha
初学者
11,317 次查看
You are awesome dude, this is worked also for me. And I sign-up just to thank you. So, THANK YOU..
AlHill
超级用户
14,497 次查看
You are still in SATA mode, correct? That will not work.
Doc
0 项奖励
JRuru
初学者
14,497 次查看
Hi Doc,
So what should i do ?
I'm confuse
Jemmy
0 项奖励
AlHill
超级用户
14,497 次查看
You cannot be in SATA mode.
I am reluctant to have you do anything at this point, as it may require you to reinstall the OS, which would also mean backing up your data.
Doc
0 项奖励
LeonWaksman
超级用户
14,499 次查看
Leon
0 项奖励
JRuru
初学者
14,497 次查看
Dear Leon & AI
After 2 days struggling with this optane, finally is running now.
The problem is in partition on HDD, i should deleted the OEM Partition contain windows OEM Recovery.
Thanks for your help
Jemmy
0 项奖励
Adam5k
初学者
12,530 次查看
Did you reinstall the OS to remove the recovery partition?
0 项奖励
LeonWaksman
超级用户
12,515 次查看
0 项奖励
回复
