Intel® Optane™ Memory
1391 Discussions
Optane Memory setup says "unsupported chipset"
Sumit04
So I bought Optane 32GB and whenever I try to set it up it says Unsupported Chipset. I have a B360- PRO Gaming motherboard by ASUS and on their website it says the MB is Intel Optane Ready. I have a i5-8400 and I checked Intel's website and everything is compatible. My OS is on a NVME and although I know you cannot accelarate a NVME drive I was planning to accelerate my HDD 1TB WD Drive. I have checked and adjusted all the settings in my ASUS UEFI BIOS and I can confirm that the SATA mode is SATA mode is an Intel® Optane™ memory Enabled selection, not AHCI. INTEL RST is enabled on my BIOS and I downloaded the driver to the latest version. CSM is also disabled. Here is the log below for more info. Someone please find me a fix or please let me know if exchanging it for a new OPTANE might solve the issue as it comes up as a storage device. Thanks in advance
Sumit04
Hi, I have returned the module because I spent a lot of time trying to make it work and it wasn't working. Followed many guides and tutorials on youtube and none of them worked.
DiegoV_Intel
Hi SSach2,
Thank you for posting in the Intel® communities.
I’m a little confused about your description. Even though, you got the error about the chipset, you were able to install the application, right?
On the other hand, could you please download the Intel® System Support Utility (SSU) from the following site and run the full report? This tool will collect your system details so we can check if there is any issue related to the chipset. Please run the full report and export the data in a text file so that you can attach that file in your response: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
I will be waiting for your response.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi SSach2,
Just wondering if you have any updates about this.
Diego V.
Sumit04
DiegoV_Intel
Hi Sumit04,
Thank you for the update.
We’ll consider this thread as closed, but if you ever have another issue or concern, please don’t hesitate to open a new thread. We can try to help you in any way possible.
Diego V.
