Intel® Optane™ Memory
Annonces
1387 Discussions
There are no valid disk pairs in your system
Thenuka_Sandun
6 975 Visites
when i was using the computer, notification message came may times that indicate the error of intel optane memory. in intel optane memory and storage management application is showing that "there are no valid disk pair in your system". what that mean? is there anything issues with disk or hardware?
0 Compliments
LeonWaksman
Super utilisateur
6 907 Visites
Hi @Thenuka_Sandun
You don't have an Intel Optane Memory Module installed in your laptop. Your storage consists an 250GB NVMe SSD and 1TB HDD. So, in order to get rid of the annoying warning just uninstall the Intel Optane Memory and Storage Management application (is not needed on your system). You will find it in Apps and Features (Windows Settings).
Leon
Voir la solution dans l'envoi d'origine
8 Réponses
LeonWaksman
Super utilisateur
6 960 Visites
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
Thenuka_Sandun
6 945 Visites
I really appreciate your help and I attached the text file that with results from SSU app.
0 Compliments
LeonWaksman
Super utilisateur
6 908 Visites
Hi @Thenuka_Sandun
Leon
Thenuka_Sandun
6 889 Visites
Thankyou for your kind solution. if I'll uninstall the intel optane Memory and storage management application, will it affect to the performance of the computer. Also i want to know some general knowledge about the laptop. How can i check the Intel Optane Memory Module  facility available for my laptop type. Because I have little doubt about vender. if this problem relate with the vendor, i will be able to check with them. looking forward to your kind reply.
0 Compliments
n_scott_pearson
Super utilisateur
6 932 Visites
A pair would include an Optane module and a HDD/SSD. Your report shows that you do not have an Optane module in your system. In general, if you are not using RAID and you are not using Optane, you have little need for the complication of and should probably uninstall Intel RST.
Hope this helps,
Thenuka_Sandun
6 889 Visites
Thankyou for your kind attention.
is including the optane module affect to the machine performance. Because i have both HDD ans SSD memory.  Also i want to know, what is the best solution to overcome that issue.
0 Compliments
LeonWaksman
Super utilisateur
6 872 Visites
Uninstalling  the Intel Optane Memory and Storage Management will not affect your laptop performance. Since you don't have an Optane Memory you don't need this application. If you have a free M.2 slot, theoretically you can install Optane Memory Module to accelerate your secondary drive (the 1TB HDD). However, my advice is not to bother with Optane Memory. The configuration you have now: NVMe SSD for Windows and Programs and large HDD for Data storage is better than the one with Optane Memory. So, just uninstall the Intel Optane Memory and Storage Management and enjoy your laptop.
Leon
Thenuka_Sandun
6 847 Visites
okay. I got it. thankyou very much for your guidance.
0 Compliments
Répondre
