Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
483 ディスカッション
Optane 905p u.2 cannot be recognised in NUC 13 BIOS, but can be in Windows (NUC 13 Extreme)
W_Z
ビギナー
2,169件の閲覧回数
I just purchased the Optane 905p 1.5T u.2 for my NUC 13 Extreme (NUC13RNGi9), and I want it to be used for my OS. I am using the Intel m.2 to u.2 adaptor which comes with the box.
However, the Optane 905p cannot be recognized in the BIOS, thus I cannot use it as my sole boot device. The strange thing is that I have another m.2 SSD (Solidigm P44 Pro 2T) that installed Windows 10, and my 905p can be recognized in Windows if the system is booted through the other m.2 SSD. In Windows 10, I can see 905p's disk full info in MAS and it can work as a full-function storage disk.
I tried installing Windows 10 in 905p through a USB drive and it works. I can choose to run the OS on 905p but I cannot use the 905p alone as the sole booting device.
I updated both the 905p's firmware and NUC 13 Extreme's BIOS, and it still cannot be recognized in NUC's BIOS. I know Intel Optane 905p is not on the compatibility list of NUC 13 Extreme, but as a products made by Intel, customers assumed it has better compatibility than other brands (I know other u.2 SSDs works flawlessly on NUC 13 Extreme).
Is there anything I can do to fix this?
ラベル(2)
0 件の賞賛
1 解決策
W_Z
ビギナー
2,127件の閲覧回数
OK, problem solved.
The conclusion - though the BIOS of NUC 13 Extreme cannot show on the STORAGE page ("not installed"), it can be seen and manageable in the BOOT page.
元の投稿で解決策を見る
1 返信
W_Z
ビギナー
2,128件の閲覧回数
OK, problem solved.
返信
