Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
SSD firmware updating via USB?
FWest1
I consider purchasing a 540s 240 GB, as a replacement for the HDD in my Lenovo desktop PC.
I'd like to update the SSD firmware before I clone the HDD content to the SSD.
Will the Intel SSD firmware update utility allow a firmware update of the SSD, when the SSD is still outside the PC (connected to the PC by USB cable)?
Thanks for the info.
Fritzz,
The firmware update for the Intel® SSD 540 Series is only available through the https://downloadcenter.intel.com/download/18363 Intel® SSD Firmware Update Tool and this procedure requires that your SSD is connected via SATA and not through USB. For more information about usage instructions please see the http://www.intel.com/content/www/us/en/support/solid-state-drives/000020439.html User Guide for Intel® SSD Firmware Update Tool
NOTE: Before initiating the Intel® SSD firmware update, be sure to read and follow the instructions included in the firmware update guidelines, and https://downloadmirror.intel.com/18363/eng/Intel_SSD_Firmware_Update_Tool_2_1_5_Release_Notes_012.pdf release notes. It is important to back up all relevant information to avoid data loss.
Through this link: https://locate.intel.com/ https://locate.intel.com/ you may locate an Intel partner/re-seller in order to by your Intel® SSD.
Let us know if you have any additional questions or doubt.
Aleki
Fritzz,
Aleki
