17257 讨论
Are Unpacked Array Supported in Platform Designer's Component Editor?
TuckerZ
新分销商 II
3,148 次查看
I'm trying to design an Avalon MM Slave and turn it into a component for use inside of platform designer using the component editor.
In my top level HDL file, I have these two ports which are multidimensional. They are both unpacked arrays of vectors
input   logic [AVALON_BUS_WIDTH - 1 : 0] coe_status_reg [NUM_STATUS_REG - 1 : 0],
output logic [AVALON_BUS_WIDTH - 1 : 0] coe_control_reg  [NUM_CONTROL_REG - 1 : 0]
I load the appropriate HDL file into Synthesis Files section of the Component Editor's Files tab. When analyzing synthesis files, I run into these errors.
Error: Verilog HDL or VHDL XML Interface error at avalon_mm_adapter.sv(46): port "coe_status_reg" has an unsupported type File: /users/223063335/documents/projects/xxx/hdl/hdl/avalon_mm_adapter.sv Line: 46
Error: Verilog HDL or VHDL XML Interface error at avalon_mm_adapter.sv(58): port "coe_control_reg" has an unsupported type File: /users/223063335/documents/projects/xxx/hdl/hdl/avalon_mm_adapter.sv Line: 58
 My questions are:
  1. Is the unpacked dimension causing this error?
  2. Is it possible to have a multidimensional array as a port in the Component Editor.
  3. If the answer is yet to Q2, how do I resolve this error?
  4. If the answer is no to Q2, how can I get around this without hardcoding the number of ports I need?
标签 (1)
0 项奖励
1 解答
RichardTanSY_Altera
3,026 次查看
May I know which version of Quartus are you using, Standard or Pro?
I'm afraid that if you are using Quartus Standard, there is limited support for the System Verilog language.
Link: https://www.intel.com/content/www/us/en/docs/programmable/683283/18-1/verilog-and-systemverilog-synthesis-support.html
The recommendations are as follows:
  1. Upgrade to Quartus Pro.
  2. Modify the design code by converting the multidimensional arrays into single-dimensional arrays.
Unfortunately, the engineering team has no plans to enhance Quartus Standard.
We apologize for any inconvenience caused by the limitations of the tool.
Richard Tan
Edited: Platform Designer does not support 2D arrays.
在原帖中查看解决方案
0 项奖励
9 回复数
sstrell
名誉分销商 III
3,126 次查看
Where are these parameter values defined?  Will the user of this component be able to set them?
0 项奖励
TuckerZ
新分销商 II
3,123 次查看
These parameters are defined in the port list. The component editor has detected them as parameters.
module avalon_mm_adapter
        parameter   AVALON_BUS_WIDTH    = 32,
        parameter   NUM_CONTROL_REG     = 1,
        parameter   NUM_STATUS_REG      = 1  )
        input   logic           csi_clk,
        input   logic           rsi_n,
        // Avalon Bus Signals
        input   logic [AVALON_BUS_WIDTH - 1 :0] avs_writedata,
        output  logic [AVALON_BUS_WIDTH - 1 :0] avs_readdata,
        input   logic [AVALON_BUS_WIDTH - 1 :0] avs_address,
        input   logic                           avs_read,
        input   logic                           avs_write,
        output  logic                           avs_waitrequest,
        output  logic                           avs_readdatavalid,
        // non-Avalon Signal
        // control outputs to fabric
0 项奖励
RichardTanSY_Altera
3,027 次查看
Richard Tan
0 项奖励
TuckerZ
新分销商 II
3,023 次查看
I am using Standard Edition.
However, it seems that Quartus Prime can handle a multidimensional port like this when just including this file outside of platform designer and elaborating it there. The problem presents itself when trying to use platform designers component editor. Are the requirements/capabilities between the two different?
0 项奖励
RichardTanSY_Altera
3,018 次查看
Yes, they may indeed different, as they serve different purposes within the Quartus Prime software.
Richard Tan
0 项奖励
TuckerZ
新分销商 II
3,017 次查看
Thank you for the information, however unfortunate.
Another question then: Where can I log a request for improvements to Quartus Prime Standard Edition?
0 项奖励
RichardTanSY_Altera
3,001 次查看
We can assist you in submitting the enhancement request, but please note that the chances of the enhancement being accepted for Quartus Standard are minimal to none.
It's important to mention that our resources primarily focus on Quartus Pro, where enhancements are more likely to be considered and implemented.
We appreciate your understanding in this matter.
With that in mind, I will proceed to submit an enhancement request for this issue.
Please let me know if you have any further questions before we close the case.
Richard Tan
0 项奖励
RichardTanSY_Altera
2,937 次查看
I regret to inform you that the engineering team is unable to provide support for enhancement requests for Quartus Standard.
Therefore, I must inform you that the request for SystemVerilog support in Platform Designer has been rejected.
However, please note that if you have an enhancement request for Quartus Pro, we would be more than happy to assist you.
Feel free to reach out to us with any such requests or any other inquiries you may have.
Thank you for your understanding in this matter.
If you have any further questions or require additional assistance, please do not hesitate to let us know.
Richard Tan
0 项奖励
RichardTanSY_Altera
2,937 次查看
Thank you for acknowledging the solution provided. With that, I will transition this thread to community support.
Thank you and have a great day!
Richard Tan
0 项奖励
回复
