17261 Discussions
Blank window when running Quartus Prime Lite in sudo mode Ubuntu 18
MAlek2
Hello. When i'm running Quartus Prime Lite in sudo mode i see nothing but blank screen. quartus_prime.png
I'm running Quartus with sudo because without it Quartus stucks when generates any IP.
I tried 17.1 and 18.1 Quartus versions with the same result. I didn't have that problem on Ubuntu 16.
KennyTan_Altera
KennyTan_Altera
I will try it on my side and let u know the result soon
KennyTan_Altera
Hi, Can you make sure all the library below had been installed in your Ubuntu? libc6:i386, libncurses5:i386, libxtst6:i386, libxft2:i386, libc6:i386, libncurses5:i386, libstdc++6:i386, libc6-dev-i386 libxft2, lib32z1, lib32ncurses5, lib32bz2-1.0, libpng12 Extra for ubuntu 18.04: libqt5xml5, liblzma-dev Also extra for ubuntu 18, libpng12 is no longer available via the apt-get method, download and install libpng12 from here: https://packages.ubuntu.com/xenial/amd64/libpng12-0/download
MAlek2
I checked all libraries and it is all good. I actually can run Quartus normally. But with sudo i got this problems. Maybe there is something wrong with environmental variables?
KennyTan_Altera
Yes.. seems like I was able to see the same.. will get back to you on this.. also, can you just use it normally?
MAlek2
Yes. I can run it normally but it stuck when generates IP instances
KennyTan_Altera
Can u check on your environment variable before and after su command? Perhaps after the su command, there are some environment change. I will check on my side as well. I will check again whenever the IP instances created , it got stuck or not.
KennyTan_Altera
Not sure if you have check it?
MAlek2
I've checked environment variables and they are different. Also in normal mode i have much more variables than under sudo. I tried to copy some of them but with no success.
KennyTan_Altera
Can you copy all of them? send us a screenshot of both of your environment variable.
MAlek2
This doesn't work for me, unfortunately. My Quartus stucks at any try to edit or create PLL, FIFO, etc. Running without sudo is not an option.
MAlek2
Previously you typed that you was able to see the same thing. How did you resolve it?
KennyTan_Altera
as mention, from my side, I just dont use the su. I also face stuck issue when try to edit the megawizard. It was resolve by https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/why-does-the-megawizard-got-hang-.html
KennyTan_Altera
Make sure the below to avoid the IP stuck.
1.Install Java from Oracle. Java version after install is:
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
2. Try to install Quartus in a directory path that has no uppercase letters.
3. Right after Megawizard is opened, stretch the window out a little (drag a corner) and make it so scrolling is not necessary.
4. make sure when you launch quartus, there are no error message showing lib is missing.
